60k Service (dealer) Fuel system servicing
  #11 (permalink)
Old 03 Oct 2008, 11:12 am
crusierdad76's Avatar
Default Re: 60k Service (dealer) Fuel system servicing
Man could you see some big time car dealer sugesting to a customer well what we needs ta da here is get some water or tranny fluid on top of them pistons to clean um up---and then see the oshia folks when you are filling the shop full of smoke
and yes they ran so much better way quicker response no lag time and you know we hardly ever changed the plugs that were like a whopping .99 cents each
  #12 (permalink)
Old 03 Oct 2008, 12:55 pm
DJmart's Avatar
Send a message via AIM to DJmart
Can I actually buy this pressurized can for the rails?
Or can I use compressed air?
  #13 (permalink)
Old 03 Oct 2008, 01:48 pm
its not compressed air it is a cleaner and I think maybe like Orileys??? nappa not sure where but it should be available
  #14 (permalink)
Old 03 Oct 2008, 01:51 pm
DJmart's Avatar
not Seafoam?
I use seafoam for the carbon build up.
  #15 (permalink)
Old 03 Oct 2008, 02:00 pm
well if you could get sea foam in a spray can then it should work but all i ever see it in is a pour can
  #16 (permalink)
Old 03 Oct 2008, 02:01 pm
DJmart's Avatar
after some reading i heard its a concentrated spray.
Do you basically just pour some seafoam directly into the fuel rail?
very confused as to how exactly the dealer performs the service.
  #17 (permalink)
Old 03 Oct 2008, 02:14 pm
The way we used to do it at the place i worked was pretty simple
On some systems there is a port or a access tube where you can attach a hose
that is attached to a canister of some type of a concertated injector cleaner we would start the car and run the rpms's up then open the canister to let the cleaner go directly into the rails then to the injectors with the car running anything that it busted loose which would be really small was sucked out the exhaust
How they do a PT I dont knnwo but Id bet its really close and Cruzn said there is a way to open the rails and do the same thing
my best advice is to get it on the open road and step on it
BG Fuel Induction Service TalkieTime Tech & Performance Forum 5 26 Apr 2008 04:44 pm
All 2002 Cruisers Recalled??? zzzhuh General PT Cruiser Discussions 18 24 Mar 2004 05:12 pm
