The dealer told me i needed the 60k service for the fuel system.
What services do the dealer perform on the fuel system? I have run Seafoam atleast twice, and i run injector cleaner through the gas tank at every oil change. Do they take out the injectors and physically clean them or what? I have cleaned the throttle body too!
Check out my gallery!!! Sure to impress. |
The way the dealer does it is to take a can of injector cleaner that's under pressure and attach it to the fuel rail and empty the can into the rail which causes the cleaner to to through all the injectors and the rail and clean them up.
From what you told me, you don't need it. BUT, if it's in your owners manual as something that should be done at 60K and your still under warranty, and you don't have any receipts for all the stuff you used, if something goes wrong with any of the injectors, they won't be covered. Always keep your receipts. It's up to you if you want them to do the service. It's a good money making deal for them. Check around at some of the auto places if you want it done. They can probably do it cheaper and keep their receipt.
I had the fuel system servicing do on my pt 2004 with 55000 miles because the dealer said it needed it I bought it used but It sounds like with the seafoam and fuel cleaner you may not need this just new plugs and wires
JMO |
Is that can deal something I can buy and do my self?
Its not hard for me to do that stuff. There is no current problem with the cars fuel system, but preventative maintenance is something i usually do. Id rather not let the dealer do it because they are gonna charge an arm and a leg for it .
Does it actually blow what ever is on the tips into the cylinders?!
You should be able to buy a pressurized can of fuel cleaner at any auto store. The connector to the PT fuel rail is at the end of the rail. The rail is located in the back of the engine but towards the top next to the valve cover.
Read the instructions on the can carefully. That's just how to connect it. I'm not telling you to do it, or not to do it.
the ones w did at the place i worked the vehicles were running so the idea was that whatever the stuff was it would be heading out the exhaust----kinda like in "THE DAY" when you would (Please tell me i'm not the only one to do this) rev the car up pretty high and pout some tranny fluid down the carb to help clean the carbon out of the cyllinders-----and after the SMOKE cleared we would do the same thing and shoot gummott down the carb to clear out the oil
Yep. If your worried, you can always take the fuel rail off (not hard) keep the injectors on the rail and blow it out but I dought anything that is in the injectors is big enough to hurt the engine when it's fired up. It's only built up gunk.
| Error Codes | skylight | Tech & Performance Forum | 7 | 28 Apr 2011 03:34 pm |
| BG Fuel Induction Service | TalkieTime | Tech & Performance Forum | 5 | 26 Apr 2008 04:44 pm |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
| All 2002 Cruisers Recalled??? | zzzhuh | General PT Cruiser Discussions | 18 | 24 Mar 2004 05:12 pm |
