SHIFTING PROBLEMS
Old 04 Oct 2008, 12:13 pm
Default SHIFTING PROBLEMS
2002 Manaul PT Crusier :
At about 45,000 mile, The dealer talked me into replacing the shifier cables when I was having a problems shifting into gears. At that time it cost me over 350.00 . I now have 110,000 miles and it starting doing the same thing. I did my homewek and found that they make replacement bushings.
I repleaced the bushings and the car shifts through all gears smoothly and easily when the car ignition is off. Now here is my problem.
After the car warms up, I have a real hard time getting it into first gear and reverse. Smetimes I have to turn off the engine to put it into gear. The minute I turn off the enginem, its easy as could be. When its warm, there is no problem shifting into 2nd, 3rd or 4th gear.
ANybody have any idea what is causing this and how I can fix it without taking it in to the shop and getting ripped off.
Any help is appreciated.
Old 04 Oct 2008, 09:42 pm
soonercruiser's Avatar
Red face Re: SHIFTING PROBLEMS
Had a similar problem with mine a few months back (2006 Touring). But, my problem was 1st & 2nd gear. When the engine warms up, the fluid in the slave cylinder that disengages the clutch thins out and doesn't work as well. I had to replace the whole clutch assembly, as the slave is inside and it only comes as a whole assembly ($500+).
Frank, aka SOONERCRUISER,
2002 PT Intermittent Starting Problems, Very Long, Goes Back 3 Years BeBeCroozer Tech & Performance Forum 21 11 Jul 2011 09:30 am
Constant 05 PT Problems - what's the deal? TEAMCATLOOK Tech & Performance Forum 4 12 Jun 2008 05:58 pm
'02 Cruiser with lots of problems :( slpknt2886 Tech & Performance Forum 4 07 Aug 2007 02:17 pm
So much problems before inspection Ctown General PT Cruiser Discussions 3 12 Apr 2005 07:45 pm
Trouble shifting into 3rd gear on 5-speed GT purplept General Turbo Discussions 23 28 May 2004 12:00 pm
