MOPAR CRUISE CONTROL KIT
Old 05 Oct 2008, 02:23 pm
Default MOPAR CRUISE CONTROL KIT
I bought Mopar cruise control kit. With the help of a very knowlageable son-in-law, we finished in a couple of hours. But, it does not work, so we must be missing something. Thinking the pcm might need re-programing, I took the car to a Chrysler dealer. The service manager told me re-programing was not necessary.
After double/triple checking all connections, I contacted the Chrysler dealer who sold the kit. He called the factory and was told some of the kits contained a faulty switch (at steering column). So, they send a replacement. We installed it and still on cruise on the Cruiser!
We preformed an error code check and none were displayed. During the procedure "Cruise" appears on the control panel above odometer. So, it appears the pcm has detected the new cruise control.
Any assistance appreciated.
Old 05 Oct 2008, 02:34 pm
Default Re: MOPAR CRUISE CONTROL KIT
After CRUISE appears above the odometer (which means it's ON) what are you doing next? In order to set the speed that the car will cruise at I have to take the stalk and push in down to actually engage the control and it only works above a certain speed, about 35mph. At that time the word SET appears after the word CRUISE.
Also once it's engaged at a particular speed, a slight tap upwards increases the cruise speed by 1 mph, a slight tap down does the opposite.
I'm reading one of your other posts that says it's an 07 cruiser so things might be different in the newer models. Chrysler seems to change things just for the sake of change.
2000 PT. 100,000 miles, Original Owner
Old 05 Oct 2008, 02:41 pm
Crewzin,
You misunderstood. "Cruise" appears only while doing the error code test.
Old 05 Oct 2008, 02:45 pm
So, "CRUISE" appears when doing the error code test and not the test that tests all the dials?
I guess it's telling you there's an ERROR with the installation of your kit.
Sorry, can't help.
Old 05 Oct 2008, 03:45 pm
On our 3 PT's, what Crewzin told you is correct!! I have checked for codes and have not gotten the word cruise in the error area. Try Crewzin's suggestions to SET the cruise.
2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome
Old 05 Oct 2008, 05:07 pm
ucantcme's Avatar
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
My Cruise doesn't put "SET" after the word cruise on my dash....!
My cruiser will work at 25mph and higher. Any lower and cruise will not engage.
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
Old 05 Oct 2008, 05:37 pm
I might have been mistaken about that as I was trying to remember from memory and the "set" might have come up on one of my other cars.
Old 05 Oct 2008, 05:51 pm
On the cruise control lever, you have to push the button in (towards the steering column), The word CRUISE comes on. When you get up to the speed you wish, you pull the lever down. That sets your speed control.
Old 06 Oct 2008, 06:29 pm
First... What year model? Second is the wiring right? If you used wiring that was there it may not be right. Even though there may be wiring here and there it may not go anywhere. I just installed a cruise kit on an 08 and part of the wiring was there at the steering wheel but it didn't go any where.
part numbers Punch General Turbo Discussions 8 19 Sep 2009 08:44 pm
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 32 23 Mar 2009 08:40 pm
  Lyrics | Debt Consolidation | Premium wordpress themes | Nike Air Force Ones | Internet Businesses Online Articles
