Ok here is the problem. I have recently replaced the coil, wires and plugs along with the cam shaft position sensor. The car ran excellent right after I replaced all of these things. I drove it for about fifteen miles and turned it off for about an hour. I went to go and drive it again after an hour and it started fine but I got out on the street and got on the accelarator the car started to misfire real bad and it would not shift out of 2nd gear and the check engine light was flashing. I immediately took it to the first repair place I could find. They ran a diagnostic on it a and it came back with a misfire on every cylinder. The tech regapped the plugs and the car seemed to run fine again. I thought the problem was fixed. But after I got home and let the car sit for a while the problem started all over again. I took it up to autozone and the codes coming up now are P2305,P0304,P0300,P0128. Didn't think I would have all of these probs just changing these few things.
Spark Plugs Champion OEM with .50 gap New Wire Set New Ignition Coil New Cam Shaft position sensor |
Don't know about the codes, but you can look them up. The plug gap should be .040.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
P2305-IGNITION COIL #2 SECONDARY CIRCUIT-INSUFFICIENT
IONIZATION P0304 - Misfire detected in cylinder #4. P0300 - Misfire detected in multiple cylinders. P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature) Looks like you didn't plug something in correctly, or did it incorrectly since it was only after you replaced all that you mentioned.
My Baby: 01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles, In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II, back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier. Check me out on Car Domain! |
Another question to go along with the rest. Why was the Camshaft position sensor replaced? Were you getting a code for that?
I would take your time, pull everything you did off including the sensor and re-install it all making double sure your doing it right. There's a "target magnet" located in the Camshaft Position Sensor area under the sensor. Did you touch that at all? The magnet has two dowels that have to line up with holes at the end of the camshaft. It can be inserted without lining up the dowels and will cause all kinds of problems.
Maybe you're right, but I had nothing else to do and he wanted to know what the codes were so I helped out.
Sorry for the delay getting back. I was playing Army the last few days. The reason I changed the Cam Shaft positioning sensor is because I originally had a code for it. I just changed the sensor and not the magnet. I thought the 2.4 turbo was still supposed to be gapped at .50. I will try and and switch the coil back and see if that corrects the prob. The car has 100,000 miles on it. Btw I knew what the codes were already and I know they were posted all over the site. I was just trying to put as much info as I could to help with the diagnosis.
Speaking of telling as much as you can. You have 100K on the engine, was the timing belt changed as recommended? It could be slipping, getting ready to break and causing your problems. Along with the timing belt, the water pump, serpentine and alternator belt should also be changed plus the belt tensioner.
| 2003 Pt Cruiser Turbo - AC DONT WORKIE | ptshmoozer | General PT Cruiser Discussions | 4 | 15 Apr 2008 11:42 am |
| Major Turbo problems | Iris | Turbo Performance | 7 | 04 May 2004 07:06 pm |
| 2003 TURBO UP, COLD AIR INTAKE | amx1397 | Vendors & Buyers Forum | 1 | 18 Nov 2003 05:39 am |
| 2003 PT Turbo Review by AUTOTEST FILE | Gary04GT | General Turbo Discussions | 2 | 12 Jul 2003 09:14 am |
| Chrysler to Offer New Cheaper GT Turbo | skylight | PT Cruiser News and Rumors | 19 | 12 Jun 2003 02:04 pm |
