Ignition Actuator
Old 13 Oct 2008, 07:18 pm
Default Ignition Actuator
Hello Everyone...
My g/f PT the ignition switch seemed to be bad and when I took it apart I notice the rod "Actuator" which turn the ignition switch when you turn the key was broken. I need to buy this part. Is there a way to buy does anybody have one HELP!!!
Old 13 Oct 2008, 07:56 pm
Default Re: Ignition Actuator
Sounds like something you need to visit the dealer for or you might try a local locksmith.
Old 25 Dec 2008, 01:26 pm
Unhappy Re: Ignition Actuator
Originally Posted by dgarm View Post
Hello Everyone...
I am having the same problem. How did you resolve the problem?
Old 20 Feb 2011, 12:36 pm
Chrysler does not make a replacement ignition actuator, they want to sell the entire steering column. I found where I can buy a replacement actuator right here:
Rebuild Chrysler, Jeep and Dodge Steering Column, Repair Ignition, Replace Ignition Gear, Loose Tilt Column, Dodge Steering Column Parts: Stolen & Recovered-Steering Column and Ignition Parts and Instructions
The bottom line with this, they should have done the right thing and had a recall for this garbage.
Old 20 Feb 2011, 01:32 pm
Are you kidding? You want the PT recalled because you had a problem with the ignition switch? First of all, recalls are 99% related to parts that can fail and someone could be seriously hurt or die. I really don't think the ignition switch falls into that category. Second, if car dealers had to carry every single part that might break, can you imagine the parts inventory they would have? How many parts, broken down to the actuator of an ignition switch, do you think are in a car, 5 million, 10 ?? Name me another car on the road that if you went to the parts department and said you wanted something like that, they would go in the back and bring you a little package like: "sure we always carry that part because 1 in a million of our cars have had that problem".
Not to mention this thread started in October 2008 and your the second owner that asked about that part.
Old 20 Feb 2011, 01:54 pm
RIGHT ON Crewzin!!!
Jerry
2004 N/A atx --but-- Kenne Bell pcm, cat delete, turbo composite intake, Snow water/meth/sumpn., K&N Apollo/ram air, hyper-ground, port/polish/shave, Crane 12's, Eaton lifters, DCR dog whistle, Hedman ceramic 4-2-1, Zoom cam gears, Braille battery, MSD coil/one-off coil heat guard, Nology with two PC-10's, Silverstone R4YS plugs, toluene, AEM afr, Autometer vac., Aeroforce Interceptor, 180 t-stat, Gold Line drop, 2.5" exhaust, Aero 2.5" stainless muffler, two Aero stainless resonators, Amsoil Z-ROD 10w30/zinc, big filter mod with Amsoil EAO15 oil filter, Amsoil ATF and some "eye candy"
Old 26 Feb 2011, 02:49 pm
I got news for you buddy, its more than 1 in a million cars that had this problem, it is in fact a common problem with many Chrysler vehicles (I know, I did the research).And by the way it has nothing to do with the ignition switch, its the shaft on the actuator that snaps for no apparent reason. I didn't say dealers should carry every damn part that broke, but one that breaks so often should be at least available from Chrysler. Its not, you are only offered the entire steering column.Just because its not a safety issue doesn't mean they shouldn't replace obvious defective parts (like lower control arm bushings, for example).
Here is the bottom line on the PT: %#%^$#!#@$
Last edited by CREWZIN; 26 Feb 2011 at 03:04 pm. Reason: Poster banned for 10 days.
Old 26 Feb 2011, 03:02 pm
Tbird, opinion noted and then put in the appropriate file.
No, I'm not kidding either.
Jerry
Old 26 Feb 2011, 03:07 pm
Crewzin, only 10 days?
Jerry
Old 26 Feb 2011, 03:09 pm
UptownSport's Avatar
Ya, well ...
I see both your points, I'd write Chrysler. It's not the mods problem, TOTALLY
understand why you're upset.
Tell Chrysler how upset you were that this broke, and while you understand
that nothing lasts forever (except the slant-6), you'd wish a common part would
be available instead of an entire piece worth almost as much as the vehicle.
Also, it's really not GREEN to manufacturer a sophisticated piece when a small
$2 part could be replaced.
Let them know that this has really stuck in your craw (I'm sure you'll find a
better phrase) and it will affect your future car buying decisions.
My neighbor bought a BRAND NEW A-4. She parks next to my $50 Neon which
has 289K miles and has never stranded me. Computer went bad coming out
of the airport, she had to have it towed.
Some girl I dated had a 325 vert (IIRC), it had a problem the shop couldn't
solve, a slow discharge. They just put a new battery in so it'd have a little
more reserve.
She was friends with the mechanics, they told her as soon as it runs out of
warrant SELL IT!!!!!!!!!
So on the other hand, you have a car that was $12-20,000 new, and those
that have $40k cars are having problems and just paying more, LOTS more!
Not to excuse the issue.
Let us know what Chrysler says.
Ignition coil problem...maybe? pcm2a Tech & Performance Forum 19 06 Sep 2011 09:04 pm
Help. No Power Door Locks with Ignition off. Lloyd General PT Cruiser Discussions 2 15 Jul 2007 10:17 am
AGP Wastegate actuator CJJ Turbo Performance 20 30 Nov 2004 09:46 am
Ignition Questions....need help. spark plugs ptcruzin42 Tech & Performance Forum 5 15 Mar 2004 08:39 pm
Wastegate Actuator And No Need for Boost Controlle FRM3 General Turbo Discussions 11 01 Dec 2003 10:51 pm
