Hello,
I have an 05 GT Convertible that is a 5 speed manual. I am looking into upgrading to the Stage 1 and I was wondering if someone that already has one could explain more specific what the Stage 1 gives you. Yes I know it upgrades to the 235hp, but what else? Does it increase the stock boost levels? And what other supporting add-ons can be purchased to use with the stage 1? Blow off valve? Wastegate? Thanks for the info guys. |
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
I remember reading a thread a while back that mentioned having the Stage 1, the Mopar Blow off valve, and the SRT-4 stage 2 wastegate would give you a steady 18psi. I don't know if this is true or not and I don't really know what the range of power is that can be made with minimal modification. With my last car (2001 Passat 1.8L Turbo) I knew that I could put a manual boost controller on a push the boost from 8 to 13 and not have to worry about any fuel issues. But that took alots of forum reading to find that info out from people that actually tested it, and I think that the Passat / Audi 1.8 Turbo probably has more of a following then the PT Cruiser. So I haven't been able to come across as much information. So.. to give you an idea of how far I'd like to go, I'm not really interested in purchasing a larger turbo or larger injectors and when the time comes for an exhaust upgrade, it will probably be a custom job done by a shop instead of a pre-fabricated unit. With that in mind.... what are my options? BTW I've seen youtube videos of a PT making 600hp on the dyno... so I know how far it can go... unfortunately, I'm not in an "unlimited money" situation. So I'd like something reliable and cost conscience. |
BTW... I don't think I've ever gotten a 13psi spike. I usually hold at 10psi if I'm on it hard, but I don't recall seeing it go past that.
If you are looking for a fun ride then the Stage 1 and Stage 2 wga spiking to 18 is a lot of fun. The Mopar bov is a noisemaker, but if you like the sound it sounds great with the 5 speed. If you've played with a boost controller before and you want a bit more adventure then go with the Stage 1, the AGP wga and a dual stage boost controller. The AGP wga will give you PTB (part throttle boost), but you can control it with the dual stage boost controller. You saw Total Sleeper on YouTube with his 600 hp PT. That car is a one of the kind and a monster. Breaking axles is a problem, though. I think he is on the road to curing that.
If you go with Stage 1 and the AGP wga driveability will suck without a dual stage bc. In first and second gears PTB is terrible. When giving it gas the boost spikes immediately. You have to baby the gas to prevent PTB or you punch it and go like hell. There is no PTB from third gear on, though. With this set up you first set the AGP boost to 13 psi (If I haven't mentioned it a boost gauge is mandatory if you don't want to blow your motor). Then you set the boost on the first stage of the bc to 15 psi. You'll get no PTB in the first two gears. Then you set the second stage of the bc to spike to 18 psi. To defeat PTB you start out on the first stage of the bc (You can drive all day on the first stage and never get PTB) through the first two gears. Before going to third gear you switch to the second stage of the bc and then go through the rest of the gears. You'll take off like a bat out of hell when going to the second stage of the bc. I used to have to warn my wife when doing this because it snapped her head back. I had this combination on my '03 PT GT.
I think it would probably be easier for me to just go with the stage 1 and stage 2 wga. I don't really like the idea of dealing with adjustments of boost controllers or the wga. Plus, I'm not looking for a ton of power so I'm guessing i'll be happy with the first setup. And you're saying the bov isn't needed? What would you suggest in the form of air filter? Is just a drop in K&N sufficient?
And yes I do already have a boost gauge. Actually I was driving fairly spirited on the way home from work today and I wasn't able to get the gauge to read much past 5psi at all. Do you think that could be related to vacuum leakage? At idle or even off throttle while driving my gauge doesn't go lower then -16psi. Infact it never has dropped below that since I got the gauge. I was assuming vacuum leak would show if the gauge dropped lower. But if the system is air tight while not under load, then the gauge wouldn't go lower, it would just not boost as high in pressure from the leakage. Does that make sense? |
Does your boost gauge sit on zero when the car is off? You'd have to have a hellatious boost leak(s) to not boost past 5 psi. Is it a boost/vacuum gauge? If also a vac gauge when the car is running what does the vac read? If you haven't any boost leak(s) maybe the gauge is broken. This is a boost leak checker. ![]() You take the intake hose off from the turbo and put this puppy on the end of the turbo. Fill your system with 15 psi of pressure and go around the engine compartment listening for leaks. I had boost leaks on both my brand new '03 PT GT and my new neon srt-4 straight from the factory.
I do have a boost gauge. It is actually a SRT-4 gauge that i got off ebay. I wanted the gauge face to match the stock ones, so thats why i went with it.
Driving home it was spiking at like 7 and holding at 5 til i shifted. And I've definitely seen it spike past 10 before so not sure why thats all i'm getting. When the car is off the gauge does rest at 0 and when the car is just idling or i remove my foot from the gas while driving, the gauge will drop down to the -16 mark (or 16 on the left side of the 0). I do actually have something very similiar to your picture. I used it on my Passat, except on that car, I pulled the hose off the air filter box and stuffed my pipe into that hose and clapped it down. If i'm going to be attaching mine directly to the turbo, I'll need to get a rubber grommet to secure it. But it could be done. So you think my gauge could be broken? |
| Are there any step by step instructions for mopar stage 2 wastegate and or dual stage | dmkolb | Turbo Performance | 7 | 04 Aug 2010 03:44 pm |
| Stage II for PT is here! | skripo | General Turbo Discussions | 9 | 12 May 2008 09:11 pm |
| Stage 1 and 2 modules on Ebay | pdbrains | Stage Turbo Kits | 3 | 16 Aug 2007 12:06 pm |
| Tour de Lance STAGE 7 | PTRON | Non-PT Discussions | 0 | 10 Jul 2004 07:13 pm |
| Stage 2 info from SRT-4 site | dtbrks | Stage Turbo Kits | 24 | 26 Nov 2003 05:24 pm |
