front wheel bearing maintenance
Old 29 Oct 2008, 04:49 pm
Default front wheel bearing maintenance
how hard is it to pull the front wheel bearings out and clean and relube them?
"an ounce of prevention is worth a pound of cure"
Old 29 Oct 2008, 05:03 pm
Default Re: front wheel bearing maintenance
This might be of some interest. It's from PT do-it-yourself.net .........
I have a 2002 PT with 51.3k miles. As a routine service I was going to repack the rear wheel bearings at the same time I replaced the brake shoes. I found that the spindle nut does not seem to have lock tabs or double nuts like the front spindles on my race car. Is there a trick for removing the spindle nut, and are there any other surprises that I may encounter while trying to repack the bearings and replace the seals? – Bob, from Arizona.
The SM indicates that the hub and bearing is designed for the life of the vehicle and requires no type of periodic maintenance. Almost all vehicles, other than pickup trucks and cargo vans above 3/4 ton, do not have bearings that can be repacked. Those days are long gone. Hub bearing assemblies are the only way they are sold.
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
Front Hub & Wheel bearing JoeHundredAire Wheels, Tires, Suspension 2 15 Jun 2008 11:25 am
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
Leather steering wheel maintenance? 2 TONE PT The Detail Shop 6 12 Dec 2003 12:21 am
Need help fixing a lug bolt. KurtPT Tech & Performance Forum 4 12 Aug 2003 06:03 pm
