I have a 2004 PT Cruiser. I am having problems with my engine knocking. When entering the freeway, the engine light turn on then turn off when I exit the freeway. Once I exit, the engine started to knock. I quickly turn off the car. However, when I try to turn the car back on, the engine starts to knock 10 seconds after I turn on the car. No engine light on but it is still knocking. Does anyone have any suggestions? I just had an oil change last weekend and the oil levels are full.
Welcome to the forum.
Search the forum for a way of reading the stored codes in the computer or take it to an auto store like Auto Zone, Discount Auto or Pep Boys and they will read the codes for you. Bring the code/s back to us so we can help you diagnose what's wrong. Knocking is usually a sign of bad timing or low oil levels. The timing is set and adjusted automatically by the computer. Did the knocking start right after you had the oil changed? Did you buy any cheap gas lately? You can throw a can of "dry Ice" into the fuel tank. It's for the winter land will get rid of any water in the fuel.
It could have been knocking since I had my car oil changed but I don't drive much only to and from work. I only fill my tank with Shell gasoline this week. Do you think it has something to do with the way they changed my oil? The oil levels seem to be at the maximum level. Any suggestions would be grateful.
We could suggest different things but the best thing to do is find the codes stored in your computer. Of course that might just tell us that a sensor saw something wrong and set the engine fault code but doesn't tell us why the sensor saw the problem in the first place. You might have to find someone with a scanner that digs deeper into the fault code and gives more information on the WHY.
Could they have done something at your oil change place to cause the knocking? Unlikely, but you can't rule that out until you find the problem.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 31 Oct 2008 at 01:03 pm. |
I just got someone to check the computer. The code is P0301 which is misfired on cylinder 1. Does anyone else have this problem? What did you do to resolve it? Also I am curious to know if this will be cover under the warranty because my PT cruiser has less than 10,000 miles on it.
What we tell everyone, if it's still under warranty, take it back to a dealer.
Engine knock, called detinition, is usuall a timing problem as stated by Crewzen.
It can be caused by poor fuel of too low an octain rating. In any case it can be very destructive to the engine. Detinition can punch holes in the pistons, burn valves, etc. It should be fixed ASAP Last edited by GALVANIZEDYANKEE; 01 Nov 2008 at 09:48 am. |
The suggested tune up does not seem a good idea until the initial problem is solved. The knock, as stated before, is usually detination. There is a ping detector (piezo electric microphone) that changes the engine timing when ping is detected. It acts so fast, and is so sensitive that it all ocurs before you can hear the ping. They do go bad.
Run the diagnostics before spending any money. |
My problem was resolve by replacing all spark plugs. This solution might help with the misfiring in the cylinder.
| Car over Heated white smoke knocking noise dying | Ctown | General PT Cruiser Discussions | 26 | 28 Apr 2009 06:03 pm |
