Thermostat housing replacement
Old 11 Nov 2008, 02:10 pm
Default Thermostat housing replacement
Hi All:
First post. Bought a super clean, stock '02 Limited with only 44K from the original owner a few months back. Have over 50K on it now, and the only problem is a slow leak from the thermostat housing. Re-torquing it didn't fix the problem, so I'll replace it, along with the thermostat, plugs, and plug wires, while I'm at it.
Question - is there a gasket for the housing, and are there any gaskets on the intake that need to be replaced when I do this? I did the search, and also looked at a service manual, but couldn't find the answer.
Old 11 Nov 2008, 06:32 pm
Default Re: Thermostat housing replacement
Welcome to the Forum SRT8guy. If you search for a sticky in the main menu you can download a parts manual. That will also help you in the future.
Old 11 Nov 2008, 06:49 pm
Originally Posted by SRT8guy View Post
Hi All:
There's a rubber gasket. If you go to check it out just drain the coolant a bit with a turkey baster until the coolant level is below the housing. You can reuse the intake manifold gasket. Just be sure to cover the openings on the lower intake manifold to prevent crap from falling in.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 11 Nov 2008, 09:22 pm
This might help......
Old 11 Nov 2008, 10:16 pm
Just to be totally clear the rubber gasket is on the thermostat.
Old 12 Nov 2008, 12:43 pm
Got it. Thanks for the replies!
'02 Limited, stock except for K&N and modified airbox, Crane FireWires
'06 Magnum SRT8, a few mods
I need a broken mirror housing, please Bobster Classifieds: Want To Buy 5 10 Feb 2009 10:06 pm
airbox foam breather filter, DIY replacement ptandme General PT Cruiser Discussions 2 14 Oct 2008 11:34 pm
Symptom of dying thermostat? tony_perreault Tech & Performance Forum 6 14 May 2008 06:13 am
Thermostat Replacement SteelBlueGT General Turbo Discussions 9 28 Sep 2005 07:04 pm
02 housing results!!! silver srt General Turbo Discussions 6 22 Sep 2003 03:14 pm
