timing belt help
Old 28 Nov 2008, 11:22 pm
Default timing belt help
ok so I have the belt around everythhing but the tensioner and it seems to be about a 1/2 inch short I just can't make it around what am I doing wrong?
Old 29 Nov 2008, 12:41 am
Default Re: timing belt help
You gotta use a little elbow grease. You can work it on over the pulley. Just have patience and it will go on.
Old 29 Nov 2008, 02:12 am
yeah patience and putting the tensioner in the right location I finally got it figured out thank you for the reply
Timing Belt Replacement MarkB Tech & Performance Forum 38 30 Apr 2010 07:38 am
02 2.4L timing belt problem ronwins3 Tech & Performance Forum 18 15 Dec 2008 08:57 pm
loose timing belt and gears not moving - urgently need help pls. lanies_ptcruiser02 Tech & Performance Forum 12 12 Aug 2008 05:36 am
Timing Belt Question bmore25 Tech & Performance Forum 2 28 May 2008 11:43 am
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
