Two days ago i was driving on the turnpike north ... i was going about 70 mph and i had it on cruise control ... all of a sudden i start dropping speed i take cruise control off and then i tried to manually speed up ... my cart kept slowing down ... finallly i pulled over to the side of the road and it just died. tried to start it up again and it wont start. i had it jump started and it just wont catch on ... it will start up for two seconds if i am pressing the gass but then it will just die again. Had to have my car towed home to ocala ... i had 3 people look at it they all told me different things. 1 - "low compression to 1st cylindar" 2 - "fuel pump or alternator" 3 - "blown head gasket or burned vavle" ... i just had the spark plugs replaced and the spark coil .... i need to get it fixed and i dont have a lot of money to take it to a shop please please please help me
Norma. When it died on the road did the "check engine" light come on to help us diagnose the problem?
My 2001 did the same thing and turned out to be the wires attached to the Cam Position sensor. Find a shop or mechanic that has a scan tool that will tell you more than just the codes from the check engine light. My guess would be the Cam or Crank sensor. Also, you say you just had the plugs and coil changed. Along with the plugs, the plug wires, especially if they are original, should have also been changed and whoever did the work probably sold you the coil for no good reason. It almost never goes bad. There's no PT club in Ocala, I know, I tried to start something up but there didn't seem to be any interest, but there is plenty of cruise-ins around your area SR200/Route 40. Ask around for a mechanic that can be trusted that can diagnose your problem without taking you for a ride.
the check engine light came on started blinking and then stayed on ... everytime i try and start it the light comes on ... is this a simple fix or is my engine going to have to be rebuilt??
NO, it's almost 99% just a sensor or something small. You didn't say what mileage you have on your PT. Is it anywhere around the 100,000 mark? I doubt it as you say it's a 2007. At that time you need to have the timing belt changed along with other accessories so that could run around $1000 but don't jump to conclusions before finding out what's wrong.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 04 Dec 2008 at 10:01 am. |
07? Isn't it still under warranty?
I'm sure it's as simple as Crewzin suggested like that cam sensor. $20 part, 15 minute change. Try to fix it yourself if your car is under warranty. If that's not it, at least you have a spare which you'll need in the future.
2006 GT Convertible 5-speed Black Eibach springs/ST sway bars 19x8.5 ADR wheels 235/35, 245/35 General UHPs 20% tint/XenonEyes HIDs PTeazer Roll Pan Borla dual 2.5" cat back
She had 3 people look at it and gave her 3 different responses, that's why I told her to find someone who can direct her to an honest mechanic.
Whatever the code is, she'll have to have it towed someplace for a final diagnosis and repair.
my car has 41,000 miles on it i got it with 30,000 miles on it so there is no warranty left on it
Norma, you stated that you had the car jumped, but it wouldn't keep running. My 03 GT did the same thing when the battery died, which surprised me. You would think it would keep running after jump starting, but it died each time after several attempts. I put a new battery in it and it was just fine. Check to make sure that the battery cables are clean and making good contact.
| Dead PT/ Won't start...HELP | careyk | General PT Cruiser Discussions | 27 | 01 Dec 2010 09:55 pm |
| low vacuum, hard start after hd gasket replacement | hondoland | Tech & Performance Forum | 6 | 31 Jul 2010 07:41 am |
| honking command start | careyk | General PT Cruiser Discussions | 0 | 09 Apr 2008 07:21 am |
| Remote start with factory alarm | SwtNLwPT | Sound and Security Forum | 0 | 14 Jul 2004 10:19 am |
| My 2001 PT won't start! | envision_man | Tech & Performance Forum | 4 | 29 Jun 2004 08:30 am |
