what is this code
Old 03 Dec 2008, 09:17 pm
Angry what is this code
Hi to all the Cruisers!
I have a 2006 2.4l cruiser, and my engine light came on, I had it checked at auto zone and they gave me the code Po138. Can anyone explain if this code is sensor codes for, before and after catalytic convertor? The read out I got from auto zone also said , engine miss-fire condition repair, low fuel pump or pressure regulator, fuel pressure very high,oxygen sensores defective, fuel system runing rich or lean check other codes first. I know these are possibilities, where do i begin? Help please!:
Old 04 Dec 2008, 07:48 am
Default Re: what is this code
Welcome to the forum.
I moved your post over to the tech section.
P0138 should mean that your 02 sensor needs replacing. Your particular code is for the downstream sensor which is on the left side of the catalytic converter.
Replace it yourself or have a mechanic do it for you. Then clear all the codes (disconnect the negative battery terminal for about 5 minutes) and see how it's running and if any other codes appear.
Old 04 Dec 2008, 07:54 am
Thanks for the quick reponce I realy apreciate it I was lost you a life saver will post my results. Thank You agan!
the dreaded p0551 code - stumper djfox1 Turbo Performance 9 27 Jun 2011 03:31 pm
Mopar radio security code. Ian-PT-GT Sound and Security Forum 11 24 Feb 2010 02:19 pm
Error code trouble P0132, 1686, 1687, 1681 SolidusGorto General PT Cruiser Discussions 0 19 Jun 2008 07:59 am
Dark Plum paint code ChaosTheory The Detail Shop 3 18 Mar 2008 11:03 pm
Need diag. code info RIvey Tech & Performance Forum 1 01 Oct 2005 12:05 pm
