2006 Touring Ed A/C & rough idle
Old 22 Dec 2008, 09:27 am
Default 2006 Touring Ed A/C & rough idle
Hi! Thanks in advance for your help!
I have a 2006 Touring Edition with approx 40,800 miles on it and lately when the car is in park but idling and/or when sitting at a stop light the car sputters (rough idle?) after about a minute and then the A/C starts blowing warm. I honestly can't say for sure that the sputtering happens when the A/C isn't on but I think it has happened once or twice when I've turned the air off after it happening with the air on. Does anyone have any ideas?
I stopped in the dealership on Friday and the guy seemed to know what I was referring to but they wanted to charge me $87.50 just to look at it. Sorry but it is right before Christmas & the economy sucks I just can't see paying them that much just to look at it & then paying to fix it on top of that.
Thanks again for any help!
Old 22 Dec 2008, 09:51 am
Default Re: 2006 Touring Ed A/C & rough idle
Welcome to the forum.
Does your fan come on when you first start the engine with the A/C on? Does the temperature guage go towards the red HOT level as your sitting at idle? Do you hear any gurgling sound when you shut off the engine (like a boiling water sound)? Have you had the A/C level checked?
Sorry, but need more information if we're going to try and help.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 22 Dec 2008, 10:03 am
I'm sorry but i'm not sure what you mean when you ask if the fan comes on when I start the car with the A/C on. I try not to start it with the A/C on because I heard that wasn't good for a car's engine. I can try it though when I leave work if you tell me what to listen for. If you just mean does the air blow out of the vents then yes it does.
The temperature gauge doesn't move it just does that rough idling - kinda like it might turn off but it doesn't. No noises when I turn the car off. The A/C went out around April of this year and they replaced it (was still under warranty then) - they didn't tell me what was wrong with it though just that it went out & needed to be replaced; other than that I haven't had the A/C checked.
Thanks!
Old 22 Dec 2008, 11:35 am
What Crewzin is saying is to start the car with hood open, turn on A/C, and look at the engine fan - it should come on. If it doesn't either the fan died or switch is bad.
Also, when you turn on A/C, does idle speed increase? It should by about 100 rpm or so....
Old 23 Dec 2008, 01:20 pm
Thank you for the clarification! The fan does come on when the a/c is turned on. When I turn the a/c on the rpm needle goes down a tiny bit and then it comes back up again.
Thanks!
Old 23 Dec 2008, 07:50 pm
Have you had your ignition wires changed? Do plugs at same time - bet that's your problem. Best bet is Crane wires - www.RaceAndStreet.com The stock plugs - copper - are okay, you can get platinum if you want - they'll last longer - but the stock wires are crap.
The A/C puts a bit of load on, and the weak spark can't take it...
Old 25 Dec 2008, 12:02 am
soonercruiser's Avatar
Cool Re: 2006 Touring Ed A/C & rough idle
Plugs & wires every 30K (not OEM stuff)
Frank, aka SOONERCRUISER,
2010 Dodge Challenger SE as my day-driver.
2005 "Limited", Stage 1 Turbo Lite, the "Cowboy Cruiser".
Have now owned 5 PT Cruisers = Me PT Crazy!
Old 20 Apr 2010, 03:49 pm
JolieCruiser's Avatar
Wow! This is the EXACT same thing my 2006 Touring is doing. Last September it stalled on me and I had to have it towed to the dealer. They did some kind of idle software update and ever since my car idles rough with the AC on. I called and complained and they said the idle was just fine due to it being set by the computer so then I had to take it over to their other dealership (they lost their chrsyler part at the location I bought it from) and since I was 200 miles from the 36,000 mile warranty being up they put a new ac compressor on. It turned cold outside so didn't need to run it. Last week when it turned very warm I turned the AC on and it's back to idling rough in drive thrus or stop lights or parked with the AC on. It's ok until you hear the compressor kick on and the car shakes so hard I hear I believe the muffler or something metal rattle underneath, and then warm air comes out. If you take off it starts to cool again. Now I'm on my extended warranty and it's in the shop again and they are putting a new fan on it, hoping that fixes it. I really believe that idle update messed it up as it was fine for the first 35,000+ of owning the car. I told them if it still does it I refuse to pay another deductible. I told them how to get it to do it so they know what it's doing. Park it with the car running, AC on and wait a few minutes til the compressor kicks on and off and there it goes. Its so rough the car actually jerks like its gonna jump forward. Glad this is not my imagination!
Jolie
Old 20 Apr 2010, 04:18 pm
Dino's Avatar
You most likely need a new radiator fan, it sounds like it drawing to much power. The fans suck mine was changed at 39000. Hopefully it will be OK when you get it back.
Old 20 Apr 2010, 07:32 pm
Welcome back, Joliegirl, long time no posting!!
Stalling, rough idle, running "hard", hesitation LiLOrion Tech & Performance Forum 36 21 May 2013 12:43 pm
New PT but rough idle?? Ed Tech & Performance Forum 9 05 Mar 2013 06:38 am
Help Rough Low Idle almost cuts off.. lockupman1 General PT Cruiser Discussions 14 05 Jan 2011 01:28 pm
Ran out of gas....got rough idle now! garpike Tech & Performance Forum 12 06 Aug 2008 04:21 pm
2006 Chrysler PT Cruiser Touring Automatic Full Factory Warranty Selling Below W $109 skylight craigslist 0 07 Jul 2007 06:56 pm
