Radiator
Old 26 Dec 2008, 09:12 am
Default Radiator
Got a little leak in our radiator right where the crimp is on the bottom.Checked it all over and that is the spot it is leaking.Got a new radiator and might put it in this weekend.Anything to watch out for?check while its out?Was going to just repair it but for $95 for a new one,why?
Old 26 Dec 2008, 10:08 am
Default Re: Radiator
With repairing the fan/housing on mine (2001) the hardest thing was removing the horizontal brace across the front, about half way down. There's two bolts on either side that are almost impossible to reach. I had just gotten a new set a wrenches with built in ratchets on the end and they really came in handy.
You don't say what year your working on but it's an older model, take your time taking off the front grill as it has small plastic catches that can easily break.
I'm pretty sure you'll have to take off the upper manifold also, it you do and it's anywhere near the time for new plugs and wires, you might as well do them too.
Old 26 Dec 2008, 05:28 pm
Yes,our is a 2001 also.We just put new plugs and wirs in august so we are all set there.You said that we have to take the front grill off?
Old 26 Dec 2008, 05:56 pm
I had to take the front grill off to move the brace so the radiator would move forward to be able to lift up and out the fan housing. You won't be able to remove the radiator (I don't think) without taking off the fan housing. I could be wrong and just maybe you can lift the radiator and housing up all in one piece, but I don't think so. I think you'll have to come forward a bit to clear the manifold.
Mine when I put a new fan housing in.
AFTERMARKET RADIATOR CAPS? soonercruiser Exterior Accessories Forum 6 12 Oct 2009 12:35 am
Radiator Cracked R_I_PT Turbo Performance 2 04 Nov 2008 01:00 pm
damage to bumper and radiator support cioccolatoo General PT Cruiser Discussions 4 02 Jul 2007 01:08 pm
Radiator cap's life span LoboMX Turbo Performance 10 03 Apr 2007 11:08 am
Radiator not pulling from reserve Hotrod General PT Cruiser Discussions 5 19 Oct 2005 09:07 pm
