Rough Idle, Rough @60, check engine light NEW
Old 05 Jan 2009, 11:20 am
Dystroy's Avatar
Send a message via AIM to Dystroy
Question Rough Idle, Rough @60, check engine light NEW
I was pointed here by a friend when I posted on LJ about my worries about my car.
I hope I can get some help or ideas - Here is the deal:
2004 purple PT Cruiser - Not turbo - automaic - 46K miles
Since summer, she's started to have a rough Idle. THEN, When she rough Idled - the AC would stop running.
Then she straightened up and stopped all that, but here currently, started it back up. but WORSE!
Changed the spark plugs, checked the wires and my step-father hooked her up to the computer and nothing came up except the obvious of RPMs not being stable.
On a current NYE road trip to N.C. If we kept the speed around 60, she did NOT like that at all... would get rough and sputter. The check engine light came on....but then turned off. Then about an hour later Came on and staid on.
Rough idle has gotten bad-
Ive heard this is common amongst the P.T.s- so I am looking for help because I can't afford to take her to a shop and get ass-raped by some mechanics.
I might try to get in touch with my step dad again and see if now that the engine light is on if the computer will say "HEY FIX THIS!"
But Yeah - I'm a chick, but Ive taken good care of my girl, regular oil changes and checking of fluids I put mid-grade gas in her...ect....
- but any help would be HIGHLY appreciated.
Old 05 Jan 2009, 11:31 am
BLUEH20's Avatar
Default Re: Rough Idle, Rough @60, check engine light NEW
How many miles? (total mileage)
When last tuned? (date/milage)
What was accomplished during the tune up?
Let's do the old stand by--SEAFOAM the throttle body and this will also help clean the combustion chanbers and associated hardwar along the way. Be prepared to repalce the spark plugs if the crud is heavy--the plugs will foul out.
The mechanic is your best friend in the shop--the anal thruster usually resides in the business office!
Old 05 Jan 2009, 11:43 am
Dystroy's Avatar
Miles - 45K
Tune-up - I bought her used and was told she ha a tuneup before I bought her. (she had 30k when I bought her)
I just replaced the sparkplugs last month or so.
~Dystroy
Old 05 Jan 2009, 01:57 pm
Welcome to the Forum. I would suggest performance wires, stock wires are "CRAP". Don't care that they "look" good.
Old 06 Jan 2009, 02:19 am
if you look in the tech section on the top there is a sticky on codes and the wonderfull cruiser needs no computer to get them.
you simply turn the key from off to run three time in a row ( off, on, off, on,off, on) and look where the odometer is and it will give you the code. they are listed in the post let us know which code comes up and we will try to help you.
I have similar issues with mine and got a egr code Iam going to replace it this week and I will let you know if it works
I am trying to pry the digital cammera out of the wifes hands to take pics along the way and will try to post with some help
I know what you mean about the mechanics and females but becarful what you say here alot of us are mechanics and some may take offense to that
Old 07 Jan 2009, 09:11 pm
I was having the same exact problem with mine (02 Limited). The idle was really rough, especially while the AC was running. Getting to 70mph was a task. When it started to sputter, I would give it more gas, and the check engine light would come on. My first thought was my injectors might be clogged since I run my gas tank dry before I fuel up. I bought some Lucas fuel injector cleaner, and some Heat (gasline antifreeze) to remove any water from the tank(its really humid down here). If it drove at 30% before, it's at about 80% now, still have more problems though. The starter went out 2 days ago, took it off, got it checked today and it's bad. Glad this car was a gift because it has given me nothing but problems. Anyway, try cleaning your injectors and see if that helps.
Old 08 Jan 2009, 08:45 am
Agree. The stock wires are crap. Get good wires - like Cranes at www.RaveAndStreet.Com - also replace plugs with the wires - gap at 0.040.
That's not the only cause, but the most common one....
Old 08 Jan 2009, 04:52 pm
www.raceandstreet.com The other link possibly won't work.
Old 12 Jan 2009, 09:07 pm
ooops!
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 15 23 Jul 2010 06:09 am
Check engine light, skipping ab1 Tech & Performance Forum 2 02 Aug 2008 11:13 pm
06 turbo check engine light 06SilverTurbo Tech & Performance Forum 23 21 May 2008 02:20 pm
Faulty Check engine light? Mel K General Turbo Discussions 5 23 Mar 2007 10:06 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
