Blower Heater Problem
Old 14 Jan 2009, 09:29 am
Default Blower Heater Problem
Hello all PT'ers
My Question is it got really cold here and I plugged in my car at night
The Heater blower was pushing the air in the cabin fine in the morning but later afternoon I went to pick up the little one at school and the heater blower will not turn on. When I do try to turn it on the lights dim just a little even letting the car idle to warm up will not do anything -thermostat works fine, (the rear defroster works) but not the main blower. Could this be the resistor block? if so I'm trying to locate where it is.
2007 automatic PT Cruiser
Old 14 Jan 2009, 02:45 pm
Default Re: Blower Heater Problem
It's the same blower for heat and A/C. I say try all postions of the fan - including A/C. As far as I know, the resistor block controls the fans speed, so by trying all speeds you ought to find one that works, unless the blower motor died.
Try all positions - feet, defrost, etc., in case one path is blocked for some reason.
The fact that the lights dim a bit suggests you didn't blow a fuse, because if fuse blew, the lights would be unaffected.
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
$50 (paypal) to whoever can solve my A/C problem intend Tech & Performance Forum 5 03 May 2008 08:08 pm
Heater problem dwallace PT Cruiser Convertible Forum 16 15 Jan 2008 08:23 am
