spark plug question
Old 16 Jan 2009, 03:21 pm
Default spark plug question
hey folks i am changing plugs and wires on my wifes 07 base edition with 47k miles, it still has the originals on it. i am using crane firewires and NGK 4306 plugs. will these plugs work with the non turbo engine ? thanks
Old 16 Jan 2009, 04:01 pm
Default Re: spark plug question
I used Autolite AP5263, many use Champion 7570 gapped at .040. Don't forget to use anti seize on the plug threads and dielectric grease on the boots. Torque plugs to 13 foot pounds, snug tighten the intake manifold in this order: 5,3,1,2,4
Old 16 Jan 2009, 05:38 pm
I searched NGK and they have 4 different plugs for the Non-Turbo PT and one of them is the 4306, so YES they will fit. I think it says they comes gapped at .050 so you need to drop that down to about .042 or .040 Don't forget to use Hooligan's advise on the previous thread about the dielectric grease and Anti-Seize.
Old 05 Feb 2009, 12:05 pm
digitalpinscruiser's Avatar
Send a message via AIM to digitalpinscruiser Send a message via Yahoo to digitalpinscruiser
cool thread guys I am going to attempt to change my spark plugs and wires this saturday....its gonna be my first time changing them on my PT
2007 PT Cruiser Touring Edition
Old 05 Feb 2009, 12:31 pm
You can use the sticky on changing plugs and wires that's on top of the Tech & performance section. You don't have the EGR pipe so you can skip that part of it. It makes it a lot easier.
Old 05 Feb 2009, 12:44 pm
thanks Crewzin I just printed out those directions and thanks for the tip about the EGR pipe
Old 05 Feb 2009, 02:19 pm
For the non-Turbo you'll want the 5306. They are a hotter plug and will burn fuel more efficiently. As said, check the gap is about .040 - .042. The 4306 are more appropriate for stock Turbo PT Cruisers as the colder plug range helps prevent detonation under boost.
Old 05 Feb 2009, 04:52 pm
SoCalCruiser's Avatar
I replaced mine with the 2313..they seem to be working fine.
2006 Limited Edition, 2.4L 4-Cyl DOHC 16V SMPI Engine, Magnesium Pearl Coat Paint, AirAid Intake, NGK Plugs, Crane Wires, Freedom Design Strut Bar, front and rear eibach lowering springs & sway bars:-)
Old 07 Feb 2009, 03:39 pm
ok so all went good today I replaced my spark plugs with Champion Iridium Plugs. Also changed my motor oil too Royal Purple today. Plus a month ago I changed the pcv valve. So with all this done I will see how my MPG has changed or if it improved at all.
But thanks to the directions here changing them was pretty easy today...
Old 07 Feb 2009, 05:41 pm
Originally Posted by digitalpinscruiser View Post
ok so all went good today I replaced my spark plugs with Champion Iridium Plugs. .
Did you have to grind down a socket to get them in? I'm wondering if they re-designed them....
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
spark plug wires dzinman Tech & Performance Forum 1 28 Jul 2005 01:25 pm
Question on spark plug gapping... wyzard Tech & Performance Forum 3 07 May 2005 07:36 am
spark plug cracked heeeelp!!!! ptcruz311 Tech & Performance Forum 5 25 Sep 2003 02:12 am
