I have acquired a 2002 P/T Cruiser that appears to have a failed timing belt. The odometer shows 114,000 miles.
Years ago I used to work on foreign cars with timing belts. On some engines, timing belt failure had catastrophic results and on others it was just a matter of replacing the belt. Has anyone out there had a belt failure and what happened to the engine? Was there any internal damage, such as bent valves or broken pistons? From other threads in this forum it appears that belt replacement is no simple matter but it beats having to replace an entire engine. |
Thanks for the reply.
I had already figured out that belt-and-pump replacement was not cheap, but had not found out whether the engine might suffer internal damage. Knowing that it is a non-interference design takes a load off my mind. I have acquired the car for next to nothing as the previous owner just abandoned it when he could not afford the repairs. Aside from the non-working engine, the car is otherwise a jewel, so putting $1000 into it is not a bad investment. |
While the valves cannot hit the piston, they CAN hit one another, so a bent valve or 2 is not out of the question. $1,000 should cover it - I've read of some having it done and paid as little as $700.
| Timing Belt Replacement | MarkB | Tech & Performance Forum | 91 | 17 Jan 2013 05:28 pm |
| 02 2.4L timing belt problem | ronwins3 | Tech & Performance Forum | 18 | 15 Dec 2008 07:57 pm |
| loose timing belt and gears not moving - urgently need help pls. | lanies_ptcruiser02 | Tech & Performance Forum | 12 | 12 Aug 2008 05:36 am |
| Another timing belt question thread :) ??? | Ctown | General PT Cruiser Discussions | 4 | 24 May 2005 08:50 am |
