can anyone offer input on how complex it is to pull the head on my 07. i think i could do it, i have several years experience in auto work. but it is limited to older v-8's the most experience i have had with a FWD is a head gasket on a pontiac quad 4. the thing that worries me is if it turns into a ring, i am not equipped with a lift to safely pull the cradle.........thanks
another question, does anyone know if the oil pan can be removed with the engine still in the car, or do i have to remove the engine/cradle assembly ? i am trying to gather as much info as possible, in case i tackle the fix myself
According to my manual, the oil pan is not to hard.
1. Remove the oil filter adapter from the oil pan. 2. Remove the structural collar. 3. Remove the lateral bending brace There's 11 lines of instructions for the cylinder head but it's mostly removing upper manifold, coil, plugs, valve cover, timing belt. Draining the cooling system. Removing the exhaust manifold can be done before or after the cylinder head is removed depending on model. There's a special un-tightening sequence for the head bolts and of course the reverse when putting it back together.
hi crewzin. thanks for the new info. i am thinking more and more about doing this job.thats what happens when you owe too much on it to be able to trade it off, and cant afford to pay someone to do it. but first i am going to find someone to do a leakdown test. hopefully it will point to a bad valve. then i am going to find me a repair manual and start buying gaskets and such.
ok i just got off the phone, and i am taking it in tomorrow morning to shoot some air to it and give it a listen.
If you are the original owner you may powertrain warranty that will take care of this. Of if when you bought it you had the powertrain transfered then you are in luck.
since the original owner was a rental company, the 7/70 ended when they sold it back to chrysler
Bad piston rings is the likely culprit if adding oil helps.
| Check Engine Light came on - code 1188? | coolvirus | General Turbo Discussions | 38 | 25 May 2011 09:01 am |
| obd-II codes | Punch | General Turbo Discussions | 13 | 06 Jul 2009 06:54 pm |
| stuck valve | coco1476 | Tech & Performance Forum | 7 | 23 Sep 2008 12:34 am |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Painted Valve Covers | GLH_TC 16V | Vendors & Buyers Forum | 2 | 06 Nov 2003 04:35 pm |
