badly need help, burnt valve ?
Old 21 Jan 2009, 07:32 pm
Default badly need help, burnt valve ?
as many of you know, i have been fighting demons, well with my constant CEL code of P0302 i was doing some troubleshooting. i decided to check the compression. well its doesnt sound good. number 2 cylinder shows to have 50 pounds less than the other cylinders do. is burnt valves a likely thing on a stock pt with 47k miles. if not does anyone have other ideas of a cause .
Old 21 Jan 2009, 07:50 pm
Default Re: badly need help, burnt valve ?
Some more stuff to read.....
re: Why low compression on one cylinder?
leaking valves, low compression one cylinder.. . - Cadillac Owners Group
What will a compression test tell me? — Yahoo! Autos
Old 21 Jan 2009, 08:02 pm
hi crewzin. i understand all about how to test for low compression and the burnt valve tests but what i was wanting to know was, is this a common thing with a pt having that low of miles ? my thinking was that burnt valves were not that common of thing any more......thanks
Old 21 Jan 2009, 08:08 pm
IF you do have a burnt valve, it's the first one I've read about in all the forums I go to. Not to say there isn't another one or more but nobody has come to the forums and told us about it. Probably one or two of the mechanics on this forum have seen them in the shop.
Old 21 Jan 2009, 08:11 pm
well that makes me feel a bit better anyway. does the pt's have adjustable valves ?
Old 21 Jan 2009, 08:41 pm
You need some of our technical members for the answer to that.
Old 21 Jan 2009, 10:07 pm
hi crewzin with my luck, ill have the first one that you have heard about. the pt is idling at approx. 600 rpm and the #2 cylinder is hitting, but not hitting as solidly as the other cylinders, when i test them by pulling the plug wires.the engine runs strong when on the road, it doesnt really run bad at idle, has just a bit of vibration/shakyness to it.
Old 21 Jan 2009, 10:39 pm
The 2.4 L engine has hydraulic valve lash adjusters. Burnt valves are now a rarity. Thirty years ago it was common. Metallurgy has advanced, and most engines use sodium filled exhaust valves. These valves withstand high operating temperatures. Make sure your problem is a valve. A cracked ring will also give low compression. That will cause excessive blow-by. Check you air cleaner and make sure the PVC filter is not oil soaked.
Old 21 Jan 2009, 10:45 pm
hi yankee. i have had the filter out several times over the last few days, and everything looks fine. as far as i know. my pvc valve hose runs into my intake behind the throttle body. i pulled the hose off a few days ago and started the engine up, and didnt see any blow by coming from the pcv valve.and i also had the oil filler cap off earlier tonight with it running and there didnt show to be any smoke......thanks
Old 22 Jan 2009, 05:28 pm
ok i got another compression guage today. 3 cylinders show approx 170 lbs and the week cylinder shows approx 120 lbs. i can add oil to the plug hole and it will build up to approx 170 lbs like the rest.
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
stuck valve coco1476 Tech & Performance Forum 7 23 Sep 2008 12:34 am
Painted Valve Covers GLH_TC 16V Vendors & Buyers Forum 2 06 Nov 2003 04:35 pm
