Multifunction Stalk (switch)
  #11 (permalink)
Old 11 Feb 2009, 07:04 am
Default Re: Multifunction Stalk (switch)
A couple people have taken it apart and have not been able to repair it.
  #12 (permalink)
Old 11 Feb 2009, 01:16 pm
Teekypt's Avatar
Send a message via Skype™ to Teekypt
I had to have my MF switch replaced (bout 1 1/2 after I bought it) and I used my fogs everyday, since the day I bought it.
However, I bought my car used, so I am not sure if the previous owner ever used the fogs...
Interesting thread tho'
2003, GT, "ShuggaPlum", xenon bumper kit and Accra-Form Running Boards, custom tan/black neoprene seat covers (front & back).
Houston, TX
http://www.math.uh.edu/~tai/Today/Clean3.jpg
  #13 (permalink)
Old 30 Sep 2010, 01:58 am
Originally Posted by SRG View Post
Yes, down the steering column, the wiring harnesses do run down there. The wiper stalk is not a "module', its another switch assembly, that is bolted together with the MFS assembly.
The wiring for both is 2 separate cable assemblies.
The problem with the multi-function switch is that too much amperage runs through all the switch contacts. Too much, that is, for the cheap parts, (contacts and plastic parts). to withstand the heat build up.
I remember MX-5's write up and pictures, and agree with it all. But for anyone to say that the wiper stalk/switch assembly is part of and must be changed with, the MFS, is wrong. I know, I've done it twice, and put back the separate, wiper stalk/switch assembly both times.
The 4-way blinker relay is a plastic module that plugs into the MFS assembly. That must be unplugged off the old one and re-plugged into the new MFS, when it its installed.
srg
Yeah, before intalling the MFS first it should be unplugged. Cause if not unplug it may cause a flow of current.
mikoto | miyata
  #14 (permalink)
Old 30 Sep 2010, 03:45 am
Freezinghot's Avatar
It should be able to be repaired assuming you get the right parts and can figure out how it goes in. It seems to me that about 70% of the time i used fixing something, is figuring out how it works. Then its usually a breeze. It would probably be easier, and maybe even cheaper just to replace it though.
But it seems to me that if what CREWZIN says is true, that it would just happen again. Personally, i never use my lights without my fog lights running.
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
Replace Multifunction Switch w/fog lamps Premiere General PT Cruiser Discussions 75 02 Feb 2012 07:09 am
Multifunction switch gonzomania General PT Cruiser Discussions 16 12 Nov 2010 07:53 pm
Multifunction switch jaball0 Tech & Performance Forum 1 03 Aug 2007 08:03 pm
MultiFunction Switch Issues-HELP !!! jmack General PT Cruiser Discussions 9 21 Feb 2005 12:52 pm
Multifunction switch for postage Shini Quiet Classifieds: For Sale/Trade 0 23 Sep 2004 10:29 am
