Error code P0456 & 0340
Old 25 Jan 2009, 06:31 pm
Send a message via Yahoo to RoadTramp113
Wink Error code P0456 & 0340
Where might I find a list of the applicable codes?
We were cruising along and lost power, stumbled a bit, then resumed right along. Happened once, then a month later hist several times in a 30 mile trip on teh freeway. I'm hoping it's not the fuel filter or pump (hate having to drop the tank). Hope it's something simple that can be fixed relatively cheap.
Old 25 Jan 2009, 06:51 pm
Default Re: Error code P0456 & 0340
Welcome to the forum.
If you look right above your post in this Tech & Performance section you'll see a sticky that says "Error Codes".
P0340 = Camshaft Position sensor circuit
P0456 = EVAP SYSTEM SMALL LEAK
The Camshaft sensor is an easy fix if it turns out to be your problem. The small leak could be even easier if it's the gas cap not being tightened. The gas cap won't cause your stumbling, the sensor would.
Camshaft sensor - right side of the engine block.
2000 PT. 100,000 miles, Original Owner
Old 25 Jan 2009, 06:56 pm
Thanx...I got the gas cap tightened...and will check out the cam sensor...I'll try the connection 1st, then replace if it continues.
Old 26 Jan 2009, 07:27 pm
The earlier pt's have a flash for the p0340. 01-03 if I remember correctly. Also a good idea to replace the cam sensor. The early ones where known to have issues.
Old 26 Jan 2009, 09:59 pm
How does the flash work? I've ordered the cam sensor...just need to get it in this weekend.
Old 27 Jan 2009, 01:18 pm
It makes the PCM less sensitive to sensor dropout. You will have to take it to a dealer to get it done.
Error Code 0340 KingKole02 Tech & Performance Forum 16 02 Oct 2008 04:05 pm
2002 Pt error code P0456 chellee Tech & Performance Forum 2 24 Jul 2008 07:56 am
code p0456 Punch General PT Cruiser Discussions 0 26 Aug 2003 02:10 pm
  Free Myspace Layouts | Wordpress Themes | Debt Consolidation | Debt Consolidation | Find jobs
