Lower engine mount
Old 28 Jan 2009, 02:09 pm
Default Lower engine mount
Hi Everybody
I need some advice on replacing the upper and lower engine mounts. Is there a certain sequence to follow? I don't want to disturb anything I don't have to. I have a 2001, with 76K on it. I appreciate any help I can get.
Thanks, Ed
Old 28 Jan 2009, 03:27 pm
Default Re: Lower engine mount
Originally Posted by ejacko View Post
Hi Everybody
Thanks, Ed
Be sure to support the engine with a jack with a piece of wood between the jack and the engine so as not to damage anything. The jack will keep the engine from moving around and causing you to have to realign it. Do the motor mounts one at a time. Do the top one first. If you haven't purchased the mounts yet don't use the stock ones. They are too flimsy. You can use the upper and lower mounts for the Neon SRT-4 as they are a lot stronger and are interchangeable with the PT.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 28 Jan 2009, 05:46 pm
Thanks Mean Grean,
Unfortunately I've purchased the mounts already. From what I'm hearing, this is a sore spot on the PT. So when they go again, I will take your advice and get the Neon SRT-4 mounts.
Thanks Again,Ed
Old 20 Mar 2009, 06:30 pm
Location: Abroad, (do miss living in the good ol'USA) due to health care costs(sorry about that all caps typo)
Hi,
My 2001 PT Cruz with only 31 K has damaged engine mounts too. (The roads here are a nightmare)
What year Neon SR-4 mounts would fit a 2001 Cruiser?
Many thanks
Old 21 Mar 2009, 02:12 am
Originally Posted by JAIMEG View Post
Hi,
Many thanks
'03 thru '05
Old 21 Mar 2009, 12:01 pm
Thanks very much for your help Mean Green.
One more tip please, my Check Engine warning light has been on for
some time but I was ignoring it with fingers crossed (There is only one
Chrysler dealership here and very incovenient to work with)
and I just checked for the codes myself using the turn the ignition on three times pointer learned here.
I got four readings:
P 1684
P 0601
P 1490
P 1495
Are these something to worry about?
Engine swap / replacement compatibility Brent72 Tech & Performance Forum 2 28 Jan 2009 07:23 pm
Engine Mount Problems chris1916 Tech & Performance Forum 1 15 Jan 2009 03:19 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Engine Mount Inserts..? Rolo Tech & Performance Forum 21 28 Jan 2004 07:08 pm
