new 2001 cruiser.....small problem....help??
Old 05 Feb 2009, 04:39 pm
Default new 2001 cruiser.....small problem....help??
Hi all...new to this forum. We have had 6 cruisers in the family over the last few years and love them. My mom just got a silver 2001 limited with a Pteazer front end and rear roll pan and that split window kit. The car has 151K miles but she only paid $3000.00 total for it. Now right after she bought it it stared stalling on her and when it happened it was if it was starving for gas. She took it to pep boys...ill never understand why??....anyways heres what they replaced for her. The wires, the plugs, they cleaned the throttle body, they replaced the manifold which they say was cracked and also the gasket. said all was good then a few hours after they left it started doing it again. then right after that the timing belt went so they had that replaced as well as the water pump...when they broke down i had my dad pull the codes and the code came up for the cam sensor so i replaced that before i knew it was the timing belt that caused them to brake down...so with all those parts replaced what could be casusing the thing to sputter every now and then? there are no codes to pull since they replaced the timing belt and i replaced the cam sensor....any ideas???
Old 05 Feb 2009, 04:56 pm
crusierdad76's Avatar
Default Re: new 2001 cruiser.....small problem....help??
could be a diffrent sensor or maybe a little water in the gas????? weak fuel pump???? kinda hard to say with out anything to go on
Old 05 Feb 2009, 08:22 pm
not sure on the gas thing..they have filled it up a few times since they bought it...if it was another sensor or even the fuel pump wouldnt it throw a code?...PLEASE HELP!!
Old 05 Feb 2009, 09:00 pm
There is a flash available for the early PT's that makes the PCM less sensitive to sensor drop out. A little roughness is normal especially at idle. Big displacement 4 cylinders tend to idle rough.
Old 05 Feb 2009, 09:08 pm
im not talking about roughnes...the car stumbles to the point of stalling and then they have to restat it and its fine for a while.....
Old 06 Feb 2009, 09:08 pm
Has timing belt been replaced?
Old 06 Feb 2009, 10:50 pm
yes 2 weeks old as is the water pump
Old 06 Feb 2009, 11:05 pm
Sorry, re-read, and you clearly say timing belt was replaced.
When it is acting up, try spraying WD-40 along the intake manifold seams - it if smooths out, intake manifold gasket leak...
(yeah, I read they replaced it, but Pep Boys?)
Check the wires to the cam sensor...
Old 07 Feb 2009, 08:14 am
Not being funny, I think I see your problem in your quote above.
I'd go over everything they did, Not replace everything but double check everything they touched.
Old 07 Feb 2009, 05:02 pm
while i agree...it was doing this before they ever touched the car so what ever they did had nothing to do with repairing what they took it to those morons in the first place to repair...its not a new problem since they replaced parts..same old problem...any ideas?
2006 PT Street Cruiser Route 66 Edition skylight PT Cruiser News and Rumors 35 17 Nov 2007 02:39 pm
iPod Interface for 2001 CHRYSLER PT CRUISER chicagoskiiguy Classifieds: For Sale/Trade 0 13 Jul 2007 11:02 am
F/S 2001 PT Cruiser - Limited Edition - 5600 mi odqlesz Classifieds: For Sale/Trade 1 19 Aug 2005 02:32 pm
2001 PT Cruiser showcar 6900 miles!! StOnEwHitePt Classifieds: For Sale/Trade 1 20 Jan 2005 04:56 am
FS: 2001 PT Cruiser Limited Edition - NY GirlyVR-4 Classifieds: For Sale/Trade 5 02 Nov 2004 03:54 am
