WHERE IS THE TRANNY MOUNT????
Old 09 Feb 2009, 03:36 am
Default WHERE IS THE TRANNY MOUNT????
Changing my brakes I realized my whole engine moves and a motor mount must be broke......from my understanding there are three I have found two...the other is a tranny mount.....does anyone have a pic or directions to find it and how hard will these be to change????? Does anyone have a step by step to changing all three?????????
Old 09 Feb 2009, 02:28 pm
Default Re: WHERE IS THE TRANNY MOUNT????
The tranny mount is on the driver side. You get to it through the wheelwell. Here is the PT manual. http://www.ptcruiserlinks.com/forum/...ir-manual.html
Seriously doubt you broke a tranny mount. The motor mounts on the pass side are extremely weak and have a history of breaking. When replacing use the Neon SRT-4 mounts as they will fit and are a lot stronger.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 09 Feb 2009, 05:51 pm
thanks man
Old 09 Feb 2009, 06:29 pm
Originally Posted by llcelebrity View Post
thanks man
You are welcome. Just in case you still want to the SRT-4 tranny mount will not fit the PT. Different tranny.
Old 13 Feb 2009, 03:38 pm
b0b88's Avatar
I removed the tranny mount last night to inspect it on my pt.. and the easiest way to get to it is to remove the airfilter box completely remove the battery/plate under the battery, and then remove the housing that holds the fusebox in place and push it back towards the firewall a couple inches and the tranny mount is right there... as meangreen said... this is probably not the issue as it wasn't with my pt either... i think all 3 passenger side motor mounts went out before the tranny mount went out hahah i already replaced one and ordered the other 2.
Old 13 Feb 2009, 03:39 pm
b0b88's Avatar
p.s. when removing the tranny mount make sure you jack the engine up using a peice of wood in between the jack and your transmission... but make sure it isnt your drain pan for the transmission your jacking the car up on ..
Old 13 Feb 2009, 03:40 pm
b0b88's Avatar
p.s.s. hahah if you dont jack the engine in place the engine will fall about 4 - 5 inches down <--- knows./..
Old 18 Feb 2009, 10:37 pm
Default ok how do you get the top right engine mount out???
ok how do you get the top right engine mount out??? once you get the bolt undone.....the ac line are there HHEELLPP
3 tranny overhauls and I now need a new one? koozy General PT Cruiser Discussions 4 31 Jul 2007 01:55 pm
Tranny cooler? sawdust123 General Turbo Discussions 2 07 Jun 2005 09:14 am
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
Burned up 2nd and 3rd gears in Autostick tranny. Rainman General Turbo Discussions 6 16 Mar 2004 01:40 pm
F/S:Motor Mount Inserts JSTANEON Classifieds: For Sale/Trade 1 11 Mar 2004 10:26 am
