Replaced thermostat, but engine temp says cold while driving...
Old 10 Feb 2009, 12:51 pm
Unhappy Replaced thermostat, but engine temp says cold while driving...
I replaced my thermostat recently when my car started overheating one day. The past few days, I start the car to warm it up, then temp gauge read normal after warming up for bout 15 minutes. Then when I start driving, the temp guage slowly bogs down to cold...and stays cold while I'm driving, and warms up slowly while at a stop light. And about every other day, I have to check my coolant, sometimes end up bones dry.
Have checked under car while running and havent seen any fluid leaking on to the ground. I have also not seen any fluid on under side of hood or on engine or anything.
Anybody have any suggestions?
Old 10 Feb 2009, 03:24 pm
crusierdad76's Avatar
Default Re: Replaced thermostat, but engine temp says cold while driving...
from the past post that i have read it sounds like you have air in the system ,and it is causing your problem you have to some how bleed all the air out of the cooling system I know i read how to do this but since i have never had to im not 100% sure
Old 10 Feb 2009, 04:00 pm
There's quite a few reasons why the PT overheats and apparently the thermostat wasn't your fault. If your loosing water and not seeing any drips or water around the engine it could be you have a bad head gasket which is letting tiny bits of water into the cylinder and burning it up.
Take it to a shop and have a compression test.
2000 PT. 100,000 miles, Original Owner
Old 10 Feb 2009, 06:45 pm
Peculiar.
When cold, take off radiator cap - is coolant up to the top?
If it were a head gasket, you'd be overheating.
You need to find where coolant is going.
Old 10 Feb 2009, 10:43 pm
well me and my dad got underneath it and check where the leak was coming from. i looked like its coming from the water pump behind the black housing and the belts (including the timing belt). we had to take the wheel off and the wheel housing to find it through the pulleys and belts. sound right?
Old 11 Feb 2009, 08:39 pm
How many miles? If you do water pump, might as well do timing belt, too, since it same labor....
engine washing thomasandrewwilliams The Detail Shop 30 06 Aug 2009 05:12 pm
2004 GT started lurching while driving, engine light came on Larndeb General Turbo Discussions 2 03 Sep 2008 04:22 pm
ac and engine temp morrisbeer General PT Cruiser Discussions 1 12 Jul 2008 07:13 pm
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
engine temp johnny Tech & Performance Forum 6 03 Mar 2003 04:15 pm
  Debt Consolidation | Spanish Property | Debt Consolidation | Debt Consolidation | WoW Gold
