Took my own advice
Old 10 Feb 2009, 04:21 pm
Default Took my own advice
I was cleaning up the engine compartment yesterday and doing a full detail. Took off the air cleaner and in order to do that I had to take off a vacuum line and air temp sensor out of the intake. I bent the very small, very fragile little tip off the air sensor and when I bent it back it halfway broke but not all the way. After cleaning I carefully put it all back together and as soon as I started it up, the dreaded engine light came on so I knew I'd need a new sensor. $29 later I had a new one in my hands. The PT wasn't running bad but the light stayed on.
So I took the air cleaner off and found out the tip had broken clean off, swallowed up and through the throttle body into the engine. I put the new sensor on, took the negative battery cable off for 5 minutes (never lost the pre-set radio stations) and took it for a ride.
The engine light is off and it's running fine. No ill effects from swallowing the little blue sensor tip. In fact if anything, it's running really good. Took it up to triple digits just for a minute (old airport road - no traffic) and it ran really good.
Got a break that time.
Old 10 Feb 2009, 04:45 pm
Default Re: Took my own advice
Lucky guy. You won't lose the preset radio stations unless you step on the brakes while the negative cable is off.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 10 Feb 2009, 04:54 pm
Didn't know that, thanks.
Old 10 Feb 2009, 05:08 pm
crusierdad76's Avatar
So your crusier will hit 100mph Im impressed hope it all works out
Old 10 Feb 2009, 05:20 pm
Originally Posted by crusierdad76 View Post
So your cruiser will hit 100mph? I'm impressed, hope it all works out
There's a speed governor on the PT (at least on mine) that stops me at around 110. I've felt it come on and it stops you in your tracks until you go below the set speed.
Old 11 Feb 2009, 08:33 am
I know about that but for some reason mine shuts off way before 100mh but hey that is probably a good thing officer
Old 11 Feb 2009, 08:39 am
Crusierdad76. Yes, your probably right.
MG if your still there. I did keep the pre-set stations as you mentioned but my clock was three hours off ??? Only had the negative cable off for about 5 minutes.
Old 11 Feb 2009, 11:17 am
BLUEH20's Avatar
Speaking of Speed Limiter-mine usually cuts in at about 75 mph--it does, however, seem to allow higher speeds when she is not in the car with me.
Old 11 Feb 2009, 11:49 am
Oh man that will got you in deep trouble
Old 11 Feb 2009, 12:58 pm
Johns Steel Blue's Avatar
I'm still trying to figure out the need to go 100MPH
John
People say I have a drinking problem. I Drink... I Get Drunk... I Fall Down... No problem! ! !
Need some advice !!!! blarneyny PT Cruiser Convertible Forum 0 31 Jul 2005 03:31 am
Advice on Bridgestone Potenza tires, please stargazer Turbo Wheels/Suspension/Handling 20 29 Oct 2004 01:46 am
Advice On Selling... Cruizin2k General PT Cruiser Discussions 12 02 Jun 2004 01:07 pm
Road trip Advice PianT Non-PT Discussions 22 13 Mar 2004 09:12 am
Investment Advice Gary04GT Non-PT Discussions 9 20 Feb 2004 07:00 pm
