Please help, i am trying to get my daughters pt cruiser running and having problems. I have no fire at the spark plugs. She had a mechanic replace the camshaft and crankshaft sensor but still no fire. Thanks bentonggbn
Yes have new plugs and wires. I am getting no spark from the wire to the plug. No fault codes are present either. Could the ignition coil where the wires plug into be bad?
Thanks for the help |
Possible, but very unlikely. If you do get a coil - don't waste money on an aftermarket one, the stock one is actually more reliable than others.
Ok Thanks, Autozone said they can ohm out the coil and see if it is bad before i buy one. I'll take it off and check this weekend.
Thanks |
Well I tried a coil and that didnt work either. i still have no spark to the spark plugs. Can anyone help me please?
It's sounding more like what QSD suggested, the ECM (Engine Control Module). I've also read that the Crankshaft Position Sensor will also cause the same problem but I know you have replaced it. Did the mechanic trace the wires of the sensors to make sure they aren't corroded, burnt or brittle. My wires from the Camshaft sensor broke off from the engine and hung down to touch the halfshaft where they burnt right through the harness.
Well I have spent money on a PCM now and the car still will not start up. I am wondering could it be out of time or would I get a code to show that if it was? If it is out of time how can I tell?
Please help Thanks, bentonggbn |
I did a little searching and I found a weird fix for a problem of no spark. Apparently the coil pack electrical connection and the Throttle Position Sensor (located on the throttle body) use the same kind of connection plug and when the owner switched them it fired right up.
Now he was working on a head gasket and had a lot of stuff pulled off and that's why they were switched, when he put it all back together. On the same problem, a Chrysler Tech had said this (which doesn't make a lot of sense to me except to check the power pak (coil))..... make sure u have 12v on the power wire and ground pulse when trying to crank on the other wires. on the coil pack CAV CIRCUIT FUNCTION 1 K17 18DB/TN IGNITION NO. 2 DRIVER 2 A142 18DG/OR AUTOMATIC SHUT DOWN RELAY OUTPUT 3 K19 18BK/GY IGNITION COIL NO. 1 DRIVER
| 2004 Chrysler PT Dream Cruiser Series 3 | skylight | PT Cruiser News and Rumors | 10 | 18 Jun 2009 08:57 am |
| Exterior Mod List | slayerdarkcross | Exterior Accessories Forum | 8 | 22 Jul 2008 03:54 pm |
| F/S 2001 PT Cruiser - Limited Edition - 5600 mi | odqlesz | Classifieds: For Sale/Trade | 1 | 19 Aug 2005 02:32 pm |
| New 2005 Convertible PT Dream Cruiser | skylight | PT Cruiser News and Rumors | 4 | 11 Jan 2005 06:12 pm |
| 2001 Basset Hound PT Cruiser 4 Sale | Basset Hound | Classifieds: For Sale/Trade | 2 | 20 Nov 2004 10:31 pm |
