Heat / AC distribution freeze up
Old 18 Feb 2009, 08:08 am
Default Heat / AC distribution freeze up
Recently a few times have had the Air Conditioning lines freeze up from and to the condenser. At the time was running floor and defrost flow on more warmer selection than cold and after about an hour or so, flow from the ducts dropped to nearly nothing. Selected upper vents and no flwo from them. Looked under the hood and noticed the lines covered with ice and frost. After the car sat about 20 minutes, the lines defrosted and the flow was back when driving again. Seems this happens when the defrost mode or the mixed defrost / floor mode is selected.
This is happening more and more frequent now and taking less time to happen (originally was 1 hr., now about 30-40 minutes).
Why would these lines be freezing and how do they control flow from the distribustion system ?
Thanks.
'06 PT Touring
Old 18 Feb 2009, 03:07 pm
Default Re: Heat / AC distribution freeze up
Have your refrigerant checked, sometimes it happens if the freon is low.
Old 18 Feb 2009, 08:04 pm
Yup. Classic symptom.
heat and fan control ~ what to expect on 1 and 2 ? frances General PT Cruiser Discussions 7 22 Dec 2004 09:09 am
no heat at feet ?? why?? bobs turbo pt General PT Cruiser Discussions 8 23 Oct 2004 05:10 pm
heat GTCOOL Stage Turbo Kits 12 13 Jun 2004 05:59 pm
Weight Distribution PTGT_Boy General Turbo Discussions 1 14 May 2004 08:44 am
Arizona heat Geeksterman Turbo Performance 4 29 May 2003 07:08 pm
