syncros is it worth it
Old 19 Feb 2009, 12:23 am
Default syncros is it worth it
since i bught my 01 5speed 2 years ago my revere gear syncro has been having trouble and will only work if its put in a certain spot which i think is the syncro failing now my first gear is starting to go just rare occations when its coolish 20 and below is it the sycros failing or should i change the tranny fluid to see if that helps its got about 60000 miles on it
thanks chuck
Old 19 Feb 2009, 08:08 am
Default Re: syncros is it worth it
Chuck,
If I remember years back when I used to shift gears, first and reverse are the same gear and that's why they are both failing. Something might have changed in all those years though. Changing the gear oil might make a difference, but I doubt it. It can't hurt to try and it is a lot less expensive than having the tranny rebuilt. Why not take it to a transmission shop and have them give you an opinion of what it might be and what it would cost. The dealer wolud just replace it without probably even looking at it.
Old 19 Feb 2009, 07:42 pm
First thing you need to check is the bushings at the transmission side of the cables. If those are good then you probably have a synchro going out. New fluid might help. Check your owners manual to see if it takes ATF 4 or a special fluid, I can't remember which.
As far as is it worth it? Do you plan on keeping the car for another 60k or are yuo going to get rid of it soon? Buying a new car entails a payment but if you buy a new Chrysler you get lifetime warranty.... I can make the argument either way. Which way do you want me to convince you?
SERVICE CONTRACTS WORTH IT??? mjb457 Tech & Performance Forum 12 30 Aug 2006 10:50 am
is MOPAR PERFORMANCE EXHAUST worth it? Ctown Tech & Performance Forum 11 27 Apr 2006 04:46 pm
Extended Warranty, Is it Worth it? mjb457 General PT Cruiser Discussions 18 21 Jan 2006 01:03 am
Headers.. Are they worth it? harbinger225 Tech & Performance Forum 3 24 Oct 2005 05:14 am
Coors sued for 10% of net worth CREWZIN Non-PT Discussions 8 20 Apr 2004 11:41 am
