New Member needs help
Old 19 Feb 2009, 11:12 am
Default New Member needs help
My wife and I own an 05 pt cuiser 5-speed and yesterday on her way to work, it shut off at 60mph and then would not start again. Timing chain appears to be intact. After the shutoff, nothing happens when she turns the key, no fuel pump sound, starter click, nothing. I tried to pull the codes and much to my suprise-there is no power at the ODBII port. I checked the scanner on my GT Mustang and it worked. Her port is dead. I need help, any suggestions?
Jody
Old 19 Feb 2009, 11:33 am
DIYPTGUY's Avatar
Send a message via AIM to DIYPTGUY
Default Re: New Member needs help
How many miles are on the car?
My Love:
02' Gold PT Cruiser Touring: Pioneer DEH-P4000UB Reciever, Self built subwoofer enclosure w/pioneer TS-SW841D subs, Summit Turbo Muffler, Spectre Modular Air Intake, underseat neon lights, subwoofer neon strip lights, Intake Manifold Paint, exterior chrome trim, steering wheel cover.
Old 19 Feb 2009, 12:42 pm
crusierdad76's Avatar
Id for sure check the battery sounds like it somehow came unhooked
Old 19 Feb 2009, 02:44 pm
There are 91,000 miles on the cruiser, I was going to change the timing belt in a couple of weeks. I checked the belt and it is fine. I checked the battey connections and they are fine. All lights work, but no power to ignition or the ODBII port
Old 19 Feb 2009, 03:15 pm
Someone else once had a similar problem and I gave this answer after doing a search.
Check fuse #17 in the Power Distribution Center box under the hood. This fuse has a plastic pull-tab on it. It's used to control Ignition-Off Draw = IOD. The fuse is pushed in when you take delivery of the vehicle. The owners' manual explains that it's used to keep the battery from draining during extended storage. If it's blown, you will need to determine what caused it to blow. This 20a fuse won't blow unless you've added a load to the circuit or there is a component failure. It doesn't take much to blow the fuse, the addition of a stereo or alarm, or even the power window modification, if you wired it into that circuit. If you haven't added an additional load, and the vehicle self-tests check out OK, dealer service will need to diagnose the problem.
Old 19 Feb 2009, 08:36 pm
DIYPTGUY's Avatar
Also maybe check the connection on the ignition. Could be a bad connection or a rusted bolt, not allowing the current to flow. If all the other electronics work, but the car doesnt start it may be that.
My Love:
New Member CREWZIN General PT Cruiser Discussions 7 05 Jan 2009 11:41 pm
New member here with a question on tail lights digitalpinscruiser Exterior Accessories Forum 3 25 May 2008 07:26 pm
Newest member of the club! SuGamer Stage Turbo Kits 14 27 Mar 2005 04:54 pm
new member with turbo knowlege san ling General Turbo Discussions 4 12 Aug 2003 06:56 pm
NEW MEMBER NEED HELP INSERTING PIC ON FORUM blue Testing 1 18 Jun 2002 02:36 pm
