ok how do you get the top right engine mount out???
Old 19 Feb 2009, 04:53 pm
Default ok how do you get the top right engine mount out???
ok how do you get the top right engine mount out??? once you get the bolt undone.....the ac line are there HHEELLPP
Old 19 Feb 2009, 06:25 pm
Default Re: ok how do you get the top right engine mount out???
Not sure but reading this might help....
Any caution to lift engine?
Old 19 Feb 2009, 07:38 pm
The A/c lines are the biggest hindrance. You can push them to a certain extent and not have a problem. If you have access to an a/c recovery unit it makes it a lot easier. Otherwise it'll just take some elbow grease, some to a lot of cussing and hold your tongue just right and it will come out.
Old 20 Feb 2009, 12:13 am
OK GOT IT!!!!!!!!!!!!!!!!!!! Changed both top passenger and bottom passenger and I am still getting some movement of the engine.........i have it on jack stands and when i do gas and brake on and off the motor is still moving not as much but there is still movement....WHAT NOW????????????
Old 20 Feb 2009, 03:56 am
There will always be some movement.. how bad is it? how much does it move?
Old 20 Feb 2009, 07:56 am
I agree completely with 02ltdPT. There's supposed to be some movement otherwise you'd feel every vibration the engine made ....and you really wouldn't like that.
Old 20 Feb 2009, 11:44 am
It moves a lil dont know really how to gadge it seems to be a lil to much for normal but i dont know really........I replaced the upper passenger side and lower passenger side.....what other ones can i check....is there only the tranny mount left or are there more???????
Lower engine mount ejacko Tech & Performance Forum 5 21 Mar 2009 12:01 pm
Engine swap / replacement compatibility Brent72 Tech & Performance Forum 2 28 Jan 2009 07:23 pm
Engine Mount Problems chris1916 Tech & Performance Forum 1 15 Jan 2009 03:19 pm
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Engine Mount Inserts..? Rolo Tech & Performance Forum 21 28 Jan 2004 07:08 pm
