In addition to the aforementioned, I noticed while driving today that the pick-up seemed to be a lot less than normal. It seemed as if the engine was trying too hard for a while, then smoothed out. AND, on top of that I almost got into a wreck, not my fault in the least. Bad day...
Also, I question the EGR valve because when I come to a stop, the car seems to surge. I did some reading on the forum and this is often diagnosed as being a faulty EGR valve. However the surge could be from spark plug wires too i guess? George
My Love: 02' Gold PT Cruiser Touring: Pioneer DEH-P4000UB Reciever, Self built subwoofer enclosure w/pioneer TS-SW841D subs, Summit Turbo Muffler, Spectre Modular Air Intake, underseat neon lights, subwoofer neon strip lights, Intake Manifold Paint, exterior chrome trim, steering wheel cover. |
If I remember, 1 bolt on the EGR was a machine bolt, the other was a sheet metal screw.
EGR went away in 2003. I'd get it taken care of - the flange will get stressed and could break, or the other bolt could work out.
Apparently someone before you was changing the plugs/wires and when putting the bolts back for the EGR pipe they probably dropped it and said the heck with it and left it with just the one bolt. One is 10mm and the other is an 8mm. A little tricky to get them both in and started, plus tightened down together to get a good tight fit into the back of the upper manifold with a thin blue gasket for a good seal.
Not sure what the symptoms would be because that pipe isn't tightened but it will cause a leak. I'd try and find a bolt that would fit and get it all tightened up.
I looked it up in my 2002 parts manual but it just said "Bolt", no dimensions.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
| Check Engine Light came on - code 1188? | coolvirus | General Turbo Discussions | 38 | 25 May 2011 09:01 am |
| obd-II codes | Punch | General Turbo Discussions | 13 | 06 Jul 2009 06:54 pm |
| stuck valve | coco1476 | Tech & Performance Forum | 7 | 23 Sep 2008 12:34 am |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Painted Valve Covers | GLH_TC 16V | Vendors & Buyers Forum | 2 | 06 Nov 2003 04:35 pm |
