ques. about water pump sticky CANDACE HELP!
Old 25 Feb 2009, 01:15 am
Send a message via AIM to mtnbktrek
Default ques. about water pump sticky CANDACE HELP!
i am attempting the water pump/timing belt change today and i read the above sticky i am stuck at that mount!! NEED UPDATE IF EX.MAN. HELPED with lifting motor high enough. if anyone knows candace i would like to know what the solution was. so far everything came off easy except that mount. i have enough slack on the wires to raise motor . and do you have to remove the other half of that mount that is bolted to the frame?? wise idea to change the tensioner for timing belt? anything else should be changed? my car has 66k on it
Old 25 Feb 2009, 09:28 pm
Default Re: ques. about water pump sticky CANDACE HELP!
Yes, change the tensioner - there's a new design.
Don't know about mount, sorry...
Changing timing belt and water pump.... missingwhatsnear Tech & Performance Forum 14 13 Dec 2010 04:22 pm
Water Pump rute66pt General PT Cruiser Discussions 4 03 Dec 2009 01:56 pm
Changing Water Pump in '02 Limited Edition... missingwhatsnear Tech & Performance Forum 2 12 Feb 2009 05:06 pm
water pump replacement questions JakeBrakeIH Tech & Performance Forum 10 25 Nov 2008 07:43 pm
water neck for the water pump Boxerjl2 Classifieds: For Sale/Trade 3 31 Jan 2008 02:48 am
