2005 PT Cruiser Overheating Issues!
Old 02 Mar 2009, 07:00 pm
Default 2005 PT Cruiser Overheating Issues!
Help!
My PT Cruiser is overheating after some use. I can drive it at low speeds (below 45) without a problem, but once I get up to 50-ish, the temperature gauge begins to rise, and it won't fall back down until I shut the car off some time. The electronic fans are working just fine, and I've flushed out the radiator and put in new anti-freeze. Any hints, tips, or clues as to what the problem might be?
Old 02 Mar 2009, 08:47 pm
Default Re: 2005 PT Cruiser Overheating Issues!
Most people usually start with thermostat - but I think that'd cause overheating even at idle.
How many miles? Could be water pump is going.
You losing any coolant?
Is oil clear and was coolant you drained clear? (head gasket).
Old 02 Mar 2009, 09:12 pm
I did some searching and what most people seem to think when others had that problem is that the radiator is clogged. You say you flushed it out and put new anti-freeze. When you flushed it was it emptying out quick or slowly. Did you use the correct percentage of anti-freeze to water? The other thing I saw was a warn out water pump that couldn't keep up the revs enough to keep the water running around to cool it off when the engine got hot.
2004 Chrysler PT Dream Cruiser Series 3 skylight PT Cruiser News and Rumors 10 18 Jun 2009 08:57 am
Exterior Mod List slayerdarkcross Exterior Accessories Forum 8 22 Jul 2008 03:54 pm
2005 Dream Cruiser Series 4 - Must Sell rsbertsch Classifieds: For Sale/Trade 1 17 Nov 2005 03:19 am
New 2005 Convertible PT Dream Cruiser skylight PT Cruiser News and Rumors 4 11 Jan 2005 06:12 pm
2005 PT Cruiser Convertible Pricing and Specs skylight PT Cruiser News and Rumors 16 20 Mar 2004 11:13 am
