Timing Belt 2001 Limited 2.4L
Old 07 Mar 2009, 06:03 pm
Post Timing Belt 2001 Limited 2.4L
Lost a timing belt while driving on the freeway. What have others experienced regarding piston or valve damage on the 2.4L when loosing the timing belt?
I have the experience to replace the belt, etc. Just need some guidance.
How can you tell if there is piston or valve damage?
Thanks,
Charlie PT
Old 08 Mar 2009, 12:47 am
Default Re: Timing Belt 2001 Limited 2.4L
Only 2 ways:
1 - do the belt, then do a compression test.
2 - take off the head and look.
The pistons should be okay, but the valves can collide.
Old 08 Mar 2009, 10:26 pm
Post Re: Timing Belt 2001 Limited 2.4L
Thank you for your quick reply. I've decided to remove the head.
Have you had the head off of a 2.4L? If so are there any tricks that you could share?
Thanks,
CharliePT
Timing Belt Replacement Instructions PTFever Tech & Performance Forum 7 18 Jun 2011 01:23 pm
02 2.4L timing belt problem ronwins3 Tech & Performance Forum 18 15 Dec 2008 08:57 pm
loose timing belt and gears not moving - urgently need help pls. lanies_ptcruiser02 Tech & Performance Forum 12 12 Aug 2008 05:36 am
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
