Intermitent rough idle
Old 09 Mar 2009, 12:28 pm
Red face Intermitent rough idle
I have a 2001 Cruiser. For several months I've experienced a random rough idle. It will is rough for a few seconds then levels out then repeats in unpredictable intervals. It does not happen while accelerating or cruising, only at idle. I have replaced the plugs & wires, cleaned the throttle body and replaced hte IAC. No luck. Any suggestions.
Old 09 Mar 2009, 04:16 pm
Default Re: Intermitent rough idle
When you replaced the plugs, did you use the new .040in gap instead of what's listed? Did you make sure the wires were seated correctly?
Old 09 Mar 2009, 04:29 pm
Im actually having the same problem with my 01
It always feels like its gonna stall on me but about 10 mins ago it actually did for the first time. It started right back up but I still wanna fix the problem.
Ive noticed it only gets rough when the a/c is on.
Old 09 Mar 2009, 05:48 pm
There's loads of answers when you do a search for rough idle with and without the A/C.....
Rough Idle, hesitation
Rough Idle
Chrysler Repair: rough idle when stopped and air conditoner on, air conditoner, pt cruiser
Rough Idle/ Air on! - PT Forums - The PT Cruiser Enthusiasts and Owners Resource
Old 09 Mar 2009, 06:59 pm
Plugs gapped correctly at .040, yes/no?? New performance wires, Crane or MOPAR, yes/no? Let us know.
Old 10 Mar 2009, 01:41 pm
I believe I used the factory gap not .040, I'll have to check (once the rains stop). I used factory plug wires from a dealer and they were fully seated when completed.
Old 10 Mar 2009, 03:37 pm
Always, always, always check the setting on the plugs before installing. I have seen plugs from the box to be anywhere from .030 to .050 out of spec. both over and under spec. Be sure to use dialectric grease and anti seize on your plugs and wires. Torque plugs to 13 foot pounds. Snug the intake bolts, I use a 3/8" drive and just snug them. Replacement bolts cost $1.38, I know from experience.
Old 10 Mar 2009, 03:41 pm
Intake bolts are 8 ft lbs. Doesn't take much to snap them, Ernie, you and I know first hand.
Old 23 Mar 2009, 11:40 am
I checked the plugs, wires, etc and all seems fine. The plugs were gapped to the factory (Chrysler) setting .050" and changed them to .040". Sadly no change.
Old 23 Mar 2009, 07:29 pm
Possible intake manifold leak. I've read you spray wd-40 along the seam while car is acting up and see if it smooths out...
Help Rough Low Idle almost cuts off.. lockupman1 General PT Cruiser Discussions 14 05 Jan 2011 01:28 pm
New PT but rough idle?? Ed Tech & Performance Forum 6 03 Oct 2009 08:03 am
Ran out of gas....got rough idle now! garpike Tech & Performance Forum 12 06 Aug 2008 04:21 pm
Stalling, rough idle, running "hard", hesitation LiLOrion Tech & Performance Forum 35 30 Dec 2007 10:41 am
Rough Idle BlueBlurCruiser General PT Cruiser Discussions 15 07 May 2004 09:50 am
