gearbox faults
Old 21 Mar 2009, 02:20 pm
Default gearbox faults
Hi
I have a 2001 pt cruiser with an auto gear box, it keeps dropping out of gear and has several error codes ( p0700, p0732, p0736 andp1782 ) can anyone tell me what they mean and what could cause them and how to fix the problems
Thanks
Old 21 Mar 2009, 02:44 pm
Default Re: gearbox faults
Welcome to the forum. I moved your post over to the technical part of the forum.
P0700 Transmission Control System Malfunction
P0732 Incorrect 2nd Gear Ratio
P0736 Reverse incorrect gear ratio
P1782 P/ES Circuit Out Of Self Test Range / P1782 2-4 Pressure Switch Sense Circuit
All to do with your transmission. A scanner could be more explicit in explaining what's going on.
There's been a few problems with the solenoid pack on cruisers but I'm not saying that's your problem but it's a lot cheaper than a new transaxle.
Old 21 Mar 2009, 05:20 pm
I recently had the same thing with the transmission dropping in and out of gear. It wasn't on my Cruiser, but instead on our '02 Caravan. It turned out to be the servo's, which may be the same thing as the solenoids.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Old 22 Mar 2009, 08:21 am
2002 Limited Edition auto transmission, about 35,000 miles, one morning it started only having first and reverse. Transmission ECU box whent bad.
Warranty paid for it.
