i got pulled over because my brake lights blew. i changed them the next morning but only the driving light works but not the brake light. the center one work but not the other two. i checked the bulb housing, made sure i had the correct bulbs, and changed the brake switch. and i still dont have working brake lights. what else could it be???????
dont know im having the same problem i thought someone would tell u so i could use the information oh well tu
Guys, you have to tell us more about your PT. There's a vast difference in electronics between the 01-05 cruisers and the 06-09 cruisers.
If it's the older ones, there's a fuse in the control panel under the hood. The No#12 fuse is for the brake lights. Also look at the connections in back of the lights themselves. Make sure there's no moisture inside the lights that would blow a fuse. With two people and meter you can test if current is getting to the lights when you step on the pedal. Hillbilly. I deleted your other post in the general section. It was just a duplicate of your post here.
hey cruzin t u i dont have power at the connection on drivers side are they separate in other words do they have separate fuses one for the right and one for the left? also where under the hood would i find that #12 fuse? i swithed the bulbs from left to rt to see if i had bad bulbs i bought but that wasnt the case cant i splice in front the rt hot wire to the laft tailight if i cant get power anyway else? tu fer ur response
Do you know where the fuse box is under the hood? 10 inch black box with the red positive hook up on one side. There's only one fuse so if your getting hot to one side, it's not the fuse. Yea, you can splice from one side to the other but that's the messy/cheap way of fixing it.
I'm looking thru the electrical system diagram but it's different depending on what year the PT is. What year is yours? After looking at different years, they all seem to be wired the same, only the power distribution center is different. The main wires run back from the fuse (#12) to the brake lamp switch and some to the headlamp switch and then back to the CHMSL (Center High Mounted Stop Lamp). Before they get to the lamp they are "T'd" off and go to the separate left/right stop lamps. So If you have one working, the fuse is good. If the CHMSL is working then you have a break in the wire somewhere. You were right when you said you might have to spice into a working wire to get it fixed.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 04 Jul 2009 at 12:53 pm. |
ok mine is a 06. the night driving lights work on both sides but the brake lights dont work. i know it only one bulb for both. i had fuses checked and the bulbs are new. it is out on both sides.
projectcam2,
Did you read the post above? is the 3rd brake light working even though the actual other two tail light brake lights don't. If the 3rd brake light is out also, the problem is up front somewhere. Might be the brake light switch near the brake pedal.
hey i know how to fix it its in ur connections before the bulb
its in the connection before the bulbs it comes apart check there thats wher e its at
sorry i did not put that in there.
yes the center top one works the two on the bottom dont |
| 2006 Touring, No Brake Lights | cosmotcat | Tech & Performance Forum | 3 | 26 Sep 2008 07:19 pm |
| 2007 PT No Brake Lights Question | katfishgr | Tech & Performance Forum | 13 | 07 Jul 2008 02:56 pm |
| No brake lights , please help | csd | General PT Cruiser Discussions | 11 | 01 Apr 2008 11:42 am |
| No Brake Lights | iziris | General PT Cruiser Discussions | 2 | 18 Oct 2007 01:42 pm |
| Woox and brake lights?...I'm stumped! | divera | General PT Cruiser Discussions | 10 | 07 Jul 2005 10:32 pm |
