2001 PT
On occasion the lights on my radio which display the time or station cut out. The other lights stay on. Chrysler replaced the unit twice under warranty but it did not solve the problem. After trouble shooting I discovered that the problem only happens when the ignition switch is in the on position. If the lights are out & I turn the key to accessory position everything is fine. Whacking the steering column right around the ignition switch solves the problem, for a while. The horn stopped working a short while ago and I noticed that it coincided with the light problem on the radio. It may have been not working correctly for longer and I just didn't notice. I suspect some kind of loose connection but can't figure out how to get at the area around the ignition switch. Any help appreciated. Also See Headlight Problem |
Opened up the shroud on the steering the other day and poked about. I found all the connectors clipped together, but the large one which goes to the lock had some movement to it. you can wiggle it about an 1/8th if an inch or more at the outside edges. Also thought that there was a lot of tension on the whole harness. Managed to get an infinitesimal amount of slack where the harness is suspended from it's clip then made sure all connectors were completely seated, squarely. It's really to early to tell if it's fixed for sure, but I haven't had the problem since.
2001 Taupe Limited 5 speed manual. Bought new and the first one to be sold by the dealer. |
Hope that got it. Don't know if you have or use the wheel tilt, but some found moving the wheel either cured or caused the problem.
| Headlight Problem | Madturtle | Tech & Performance Forum | 2 | 04 May 2009 08:05 pm |
| auto-door lock or electric problem? | jsampson | General PT Cruiser Discussions | 5 | 04 Feb 2009 06:40 am |
| $50 (paypal) to whoever can solve my A/C problem | intend | Tech & Performance Forum | 5 | 03 May 2008 08:08 pm |
| I think I'm having a power steering problem! | lumofny | Tech & Performance Forum | 5 | 18 Jan 2005 01:12 pm |
| Unknown RPM surge problem (manual) | Ctown | Tech & Performance Forum | 4 | 26 Dec 2004 08:48 pm |
