Hello,
I have a 2002 touring DOHC 2.4 with 41k. Last week I installed a set of livewires, Mini-VIP ignition booster (18Volts), Screem'n Demon Coil, no-gap Bosch Platinum 2 plugs, Airaide intake and Hearthrob Dual Cat Back exhaust. Everything was good from the first crank and did notice improved performance. I now drive about 70 miles each way 5 days a week on some very steep roads and push the engine hard. Yesterday my engine light came on and stays lit solid. All fluids good, temp gauge in middle and car still runs good, no performance issues noticed. How do you check fault code for engine light and what could be the possible problem causing the light to come on. I do not want to do any damage to the engine but have to drive to work? Thankx for any advice you may have. Barry Tel Aviv, Israel |
Hello,
I just checked for the error code and it reads P0601 (PCM Fault). The car runs good, is it possible that the new parts I just installed caused the PCM to error? If so can you reset the PCM to turn off the engine light? What should I do?? B |
A search revealed numerous answers, and they don't look good. Here's a sample:
P0601 - PCM internal controller failure. When monitored = ignition key on. Set condition = internal checksum for software failed, does not match calculated value. Possible causes = PCM (no other causes) Test = none. The PCM is reporting internal errors and must be replaced. By all means get a second opinion on this, perhaps through the dealer. Basically that means that there is an interal fault in the Powertrain Control Module (PCM). There have been many reported PCM failures on Chrysler/Dodge products although it is possible for this to happen on any vehicle. In Dodge/Chrysler products, a P0601 trouble code means that a serial communication failed inside the computer at least 6 times. Symptoms Likely, no symptoms will be discernible to the driver, other than the illuminated Check Engine Light. Typically the engine runs fine, gauges work, etc. Causes A code P0601 in most cases means the PCM has gone bad. This is possibly due to a short-circuit inside the PCM. Or, if you disconnect the wires/connector from the PCM while the battery is still connected, that may also cause this code. Possible Solutions With a P0601 OBD-II trouble code, the most common fix is to replace and reprogram the PCM. In a few cases the dealer may be able to reflash the PCM and get it working. But more than likely the PCM will need to be replaced and reprogrammed (we recommend you take it to a dealership for this). The good news is it *may* be covered under your emmissions warranty. So even if you're out of bumper-to-bumper warranty or powertrain warranty, check your warranty guide or dealer to see if this is covered. Other people have reported that they cleared the code only for it to return again and again. Keep in mind that most shops can replace the PCM but not all can program it. Pull the negative battery cable off for about 5 minutes. That will clear out the codes stored in the computer and turn off the engine light, unless the fault is still there and the light will come back on.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 05 Apr 2009 at 08:09 am. |
Thankx for the info!
^I wouldn't see why it wouldn't be ok.. but I COULD be wrong.
Silver 2002 pt cruiser touring edition, auto, dark ass tint, 89k miles... shift burp mod, SRI 2005 civic ex special edition, 5spd, fully loaded, 40k miles I have a wide-band o2 sensor for sale!! PM ME!! |
66CUDA |
I may be wrong, but I think a PCM has to have VIN# put in - I know that's true for Stage 1.
^huh? a vin has to be put in in order for a pcm to work??? How does that make sense?
| "Check Engine" idiot light on AGAIN | tezz | General Turbo Discussions | 15 | 23 Jul 2010 06:09 am |
| Check engine light, skipping | ab1 | Tech & Performance Forum | 2 | 02 Aug 2008 11:13 pm |
| Check Engine Light | CHROMEDCRUISER | General PT Cruiser Discussions | 11 | 16 Jul 2008 11:46 pm |
| 06 turbo check engine light | 06SilverTurbo | Tech & Performance Forum | 23 | 21 May 2008 02:20 pm |
| Check engine oil light question | AaronR | General PT Cruiser Discussions | 5 | 28 Aug 2004 03:18 am |
