Mine was dissappearing because of a leak through the head gasket or crack between the cylinder and the water jacket... I speculate. It is at the mechanic's having the head pulled so that we know for sure. I bought Steelseal and it cured the exhaust to water problem but I also had an increasing leak between cylinder and the outside. I can hear it and the power loss is way bad. I get misfire codes in one or 2 cylinders 30x I think.
We will see what the diagnosis is for sure but I enjoy trying to figure things out based on any shred of evidence I can get. |
Have you had the PT since new? I ask because because I learned if you fill the overflow bottle to the top mark while it's cold, it'll push the coolant out. It should only be at the top mark when it's hot, at the low mark when cold.
Assuming you know that, does the PT run well otherwise? Temp gauge okay?
My response way way out there. I wasn't thinking about the op, sorry.
Look for the obvious, water on the ground, smell of anti-freeze, hissing sounds or steam from the radiator core or hoses, etc. I also had a radiator hose left "cocked off" and not properly clamped. If that seal can not hold more than the pressure rating on your cap it may spell trouble. A cheap shotgin approach is to replace the cap, check your overflow hose for leaks, and even verify that your fan works on both speeds. Quote:
My Love: 02' Gold PT Cruiser Touring: Pioneer DEH-P4000UB Reciever, Self built subwoofer enclosure w/pioneer TS-SW841D subs, Summit Turbo Muffler, Spectre Modular Air Intake, underseat neon lights, subwoofer neon strip lights, Intake Manifold Paint, exterior chrome trim, steering wheel cover. |
Stop at any decent shop with a mechanic ans ask for a radiator pressure test. It only takes a couple minutes. They apply pressure to the top of the radiator where the cap is and will force any tiny leaks to show up in the radiator or hoses.
Yes it can very likely be a head gasket. Get a local mechanic to do a pressure test but even that might not show whats wrong. You may need to take it apart to know for sure.
http://www.ineedaradiator.com |
Mine has the same disappearing coolant issue. 01 Limited. Engine runs fine. No sweet smell from the exhaust. No drips under the car. Temp gauge fluctuates between horizontal and just below. I top up the reservoir with a litre or two every three or four months.
![]() Any one know if the radiator or hoses on PTs die prematurely, or how long one should expect them to last?
2001 Taupe Limited 5 speed manual. Bought new and the first one to be sold by the dealer. |
If its burning coolant you might be able to smell it in the exhaust. If so - head gasket.
| Surging Problem 2001 PT 13k miles | thebearII | Tech & Performance Forum | 13 | 30 Aug 2010 05:39 am |
| Temperature & Coolant Problem | SRMarsh | General PT Cruiser Discussions | 7 | 13 May 2009 01:42 pm |
| Horn/Radio Problem | Madturtle | Tech & Performance Forum | 4 | 11 Apr 2009 10:54 am |
| $50 (paypal) to whoever can solve my A/C problem | intend | Tech & Performance Forum | 5 | 03 May 2008 08:08 pm |
| Unknown RPM surge problem (manual) | Ctown | Tech & Performance Forum | 4 | 26 Dec 2004 08:48 pm |
