Spark Plugs & wires
Old 07 Apr 2009, 09:34 am
Default Spark Plugs & wires
I have a 2002 PT with just over 19000 miles on it, driven once or twice a week in CA, kept in garage. A friend and expert mechanic tells me I should change the plugs and plug wires because the car is 7 years old and not just because of the low mileage. He recommended an NGK 2314 plug and some special hi-energy wires. He was concerned that not changing the plugs would make them sieze and be difficult to remove. any thoughts?
Old 07 Apr 2009, 09:43 am
Default Re: Spark Plugs & wires
Welcome.
Agree with your friend.
The stock wires are lousy, and mine started to give me a miss before 20,000 miles.
You may indeed have trouble getting the original plugs and wires out.
Gap at 0.040, put a dab of anti-seize on the threads of each plug, and dielectric grease on the wire boots (both ends).
follow this:
Spark Plug Guide
Old 07 Apr 2009, 10:00 am
Not very knowledgable about things mechanical. Should I just take it to the local dealer or would a good independent mechanic be better? About what should I expect to pay for the plugs and wires?
Old 07 Apr 2009, 10:21 am
Ask around and go to a mechanic - how about your friend?
Wires are $60-75 (depending on brand can be more) plugs a few bucks apiece. Tubes of anti-seize and dielectric grease are only a few dollars.
Takes a couple hours to do.
Old 07 Apr 2009, 11:19 am
I believe there was a thread somewhere here on how to change your plugs.It had a step by step guide with pictures.I changed mine today in about 30 minutes,most of the work is unbolting stuff just to get to them.You're gonna need a extension thats somewhat long to get down to the plugs.
2003 N/A PT,60k miles,Bomez intake with K&N filter,APP5263 plugs,8.5mm blue Magstar wires,MSD Coil,Silverstar headlights,Silverstar Ultra foglights.
Old 07 Apr 2009, 11:56 am
In my first post above the "sprk plug guide" is a link that points to the guide.
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
CHANGING SPARK PLUGS & WIRES?? mjb457 Tech & Performance Forum 10 21 Oct 2009 03:01 pm
Going for the spark plugs & wires PTC06Peet General PT Cruiser Discussions 1 19 Feb 2009 06:44 pm
Spark Plugs & Wires Recommendation For 2002 Non-turbo johnjsa Tech & Performance Forum 2 19 Nov 2008 07:47 pm
Spark Plugs and Wires install TaylorMade Tech & Performance Forum 4 05 Oct 2004 11:04 am
