Engine Light ON
Old 07 Apr 2009, 07:58 pm
Default Engine Light ON
Hello everyone! I have a 2003 PT Cruiser Dreamcruiser Turbo and I'm trying to figure out why my engine light is on. I tried to do the "RUN to OFF to Run" on the ignition and it gave me a SoF 54. Which I think may not be the code. I heard it should start with a "P".
Then I tried pressing the odometer switch while I turned the key to run where it did the "1111111" to "999999" sequence. It gave me a couple of codes which are
FL 0007
EE 11
bl 01
After this segment the fuel gauge, the speedometer, and temp gauge did the step thing where it went from 1/4 of the dial to 1/2 then to the full range of the gauges.
I still did not see a code that starts with a "P".
At the end of the process, it did not give a code and all the digital gauges just lit up and went back to the original position.
Any help will be highly appreciated.
Which non
Old 08 Apr 2009, 05:10 am
Default Re: Engine Light ON
Here's the "key trick"
Engine off.
Put key to "on" - right before start.
Back one click to "off"
then On
off
On.
Old 08 Apr 2009, 05:43 am
If you can't seem to do the "trick", take it to a local parts store (Pep Bys, Advance Auto or Auto Zone and they will read the codes for free.
Old 08 Apr 2009, 05:57 am
I see you got an error code, same problem as this post?
Code P0441
Old 08 Apr 2009, 07:49 pm
Code P0441
Yes that is the code. I did check the fuel cap and it was a little bit loose. So I tightened it yesterday and I drove it today but the "check engine light" is still on.
Do you think I should disconnect the battery to reset the codes?
thanks,
Old 08 Apr 2009, 07:54 pm
Engine off.
then On
off
On.
Quicksilver,
Thank you that did work and i got the P0441 code in regards to faulty evaporation....blah...lol
I checked the fuel cap and it seems it was not tightened... I drove it today and the light is still on... I saw in another post that I should give the computer a couple of days to figure out that it has been fixed...
what do you think?
Old 08 Apr 2009, 09:06 pm
Disconnect the negative cable for about 5 minutes, that should clear the code(s).
Old 09 Apr 2009, 08:27 pm
Originally Posted by AkiraCruiser View Post
what do you think?
Give it a bit. You won't hurt the engine - the code is for emissions. Or, you can take a battery terminal off for a few minutes. If the code comes back, try a new gas cap - they aren't much. If that isn't it, gets harder and more costly to fix.
Old 09 Apr 2009, 09:06 pm
A quick note - I got this code several times because windshield washer fluid dripped directly on the PCM connectors. Shouldn't normally be a problem, but something to look into I suppose.
P0441 is usually the gas cap. I think it takes 20 starts without the error before it clears. No harm to the engine P0441 is not a showstopper.
Old 09 Apr 2009, 09:54 pm
Thanks everyone!!! I really appreciate the help. The check engine light finally disappeared today. I guess that is one more knowledge I can keep to help me maintain my cruiser.....I guess it was just the fuel cap and it did take several trips before the code cleared itself...Thanks again...
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 15 23 Jul 2010 06:09 am
Check engine light just came on! lajag24t Tech & Performance Forum 22 13 Aug 2009 05:22 pm
Engine Light Stays On - OBD vinzchlortho Tech & Performance Forum 6 30 Nov 2008 07:01 pm
Check engine light, skipping ab1 Tech & Performance Forum 2 02 Aug 2008 11:13 pm
06 turbo check engine light 06SilverTurbo Tech & Performance Forum 23 21 May 2008 02:20 pm
