I have a 03' N/A automatic PT with 60,000 miles and it started missing right after I changed the plugs(Autolite AP5263's).So I took em back out and checked all the gaps and then replaced the wires with magstar 8.5mm wires & it still missed so I changed coil and still misses terribly,makes the whole car shake.I plugged it in to the OBDII scanner at work and it said cylinder 3 missfire.What else could it be?Maybe bad injector?
2003 N/A PT,60k miles,Bomez intake with K&N filter,APP5263 plugs,8.5mm blue Magstar wires,MSD Coil,Silverstar headlights,Silverstar Ultra foglights. |
You could have swapped around wires to the wrong cylinders but not likely. Do take a wire off of No#3 and swap it with No#2 to see if the code changes. You can do that with the spark plugs if it doesn't change to see if that makes a difference. The next thing is a compression check to see if a head gasket has problems.
I did the wires one at a time so theres no way I managed that,plus the factory coil has the cylinders numbered on it and the OBD would've picked up a misfire in cylinder 2 too.Its only getting a misfire on cylinder 3,so I don't think a headgasket would be the culprit of that..So what else could it be besides a bad injector?
According to the searches I did, a leaking headgasket can be the culprit in just one cylinder but to answer your question, yes it can also be a bad injector.
Hmmmmm. Didn't I suggest that in my first reply?
I guess Hooligan stated it a better way.
Since, you had to remove the intake to change plugs did you get a good seal when you put it back? I had a misfire code come up on my 03 turbo and it was a leaking intake gasket between the lower manifold and head on the offending cylinder.
Dave Clement \'03 GT, Electric Blue |
Thanks for all your guy's help.I'll try the plug tomorow..And I made sure I didnt have a leaking intake to answer your question.I sprayed starter fluid around the seal on all the cylinders(I know its not the best thing for it but I was desperate lol)
| Terrible Gas Mileage | TaylorMade | General PT Cruiser Discussions | 10 | 10 Oct 2011 03:46 pm |
| 2006 PT Limited Ed Mileage is terrible. | vetteloverpa | General PT Cruiser Discussions | 45 | 11 Mar 2008 12:09 am |
| A/C Smells Terrible | Scott123 | Tech & Performance Forum | 6 | 28 Oct 2007 08:38 pm |
| Crazy missfire ! | ptTurbo528 | Tech & Performance Forum | 5 | 28 Mar 2006 11:43 pm |
| Missfire & backfires | Turbo Red | General Turbo Discussions | 6 | 18 Oct 2004 07:58 pm |
