Cooling Fan No Go when AC is Turned ON
Old 13 Apr 2009, 08:42 pm
Default Cooling Fan No Go when AC is Turned ON
Have '06 PT non turbo 2.4 and the fan does not work on the "Low speed?". I assume these fans have two speeds low speed when Air Conditioner is "on" and a higher speed when engine temp hits a certain temp rise. To verify put direct 12v to fan and it does work on the "High Speed" side and does not on the "Low Speed" side. Also proved that 12v was being sent to the motor when calling for the Low speed.
Since it looks as if I will need to replace fan anyway does anyone see an issue with sharing the "High" side on the fan motor with both (+) outputs on the Low an High speed fan relays until I'm ready to replace the fan?
Old 14 Apr 2009, 07:24 am
Default Re: Cooling Fan No Go when AC is Turned ON
Nobody that I know of has tried it before, at least they haven't told us about it so just do it if you can...and let us know if it works. Your basically tricking the computer into thinking it's putting on the low speed and the high speed will come on instead. Can't see why it wouldn't work except that it will keep the temperatures quite cool. Might burn the high speed part of the fan out a little prematurely but you've lost the low speed already.
I have an auxiliary fan in front of the radiator in my Vette wired up separately with a switch. It's not supposed to come on until about 230 degrees with a thermostat. I don't like it that hot so I put the switch in. I forget that it's ON most of the time so both the normal and aux fans are running. Doesn't hurt and keeps the water temperature right about 200.
Old 14 Apr 2009, 12:37 pm
I have seen incorrect ac refrigerant pressure too much or to little cause this problem in other cars or a bad ac pressure sensor or transducer on the ac line.
Old 14 Apr 2009, 12:46 pm
I don't think that has anything to do with the fan not coming on. Thnk you meant to post your reply in another place.
Old 14 Apr 2009, 06:43 pm
I'm sorry I meant to post in the basket weaving forum.
Old 14 Apr 2009, 06:48 pm
Now, you know what I mean...another place on THIS forum where someone was having trouble with the A/C not getting cool enough.
Having "incorrect ac refrigerant pressure" wouldn't stop the fan motor from turning on which is what this thread is about.
Old 12 Jan 2011, 11:52 pm
Cooling Fan No Go when AC is Turned ON:
It is too good for those users who are not well knowledge about Cooling Fan No Go when AC is Turned ON utilities which is mention above. You can get entire information which you want. Thank you
ed hardy
ed hardy
ed hardy
Old 13 Jan 2011, 07:53 am
WHAT Would someone mind telling me what was just posted? I can't tell if it's or just a new foreign visitor trying to say something.
Old 13 Jan 2011, 09:47 am
To me sounds like spam!!!! Especially when it is attached to a 2009 posting.
Old 13 Jan 2011, 10:17 am
Has the earmarks of a spammer, but stupidly forgot to put in the spam link...
cooling fan no go on the low nealtotheking General PT Cruiser Discussions 4 29 Oct 2009 09:03 am
Cooling circuit Kirby General Turbo Discussions 3 03 Aug 2008 05:49 am
cooling fans not working ripp_jr Tech & Performance Forum 8 13 Jan 2008 07:12 pm
How to ? Check Cooling Fan '01 pffester Tech & Performance Forum 3 04 Jul 2007 08:05 pm
A/C .. and Engine cooling fan mystery delbassman Tech & Performance Forum 9 02 Apr 2007 01:14 am
