Motor mounts
Old 14 Apr 2009, 03:02 pm
Send a message via MSN to saldagus
Default Motor mounts
Are the upper and lower mounts interchangeable in the AT and MT cruisers?
Old 14 Apr 2009, 04:20 pm
PT_Cuda's Avatar
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Default Re: Motor mounts
The torque struts aka the motor mounts are the same on all PT's of all years..
pic of the torque struts what most people call the motor mounts.
The shorty is the upper and is filled with polyurethane
The long one is the lower that is a tore up stock mount.
I make people mad.. Its what I'm good at..
Old 14 Apr 2009, 04:43 pm
Just asking because when I went to my local dealership, they had different part numbers for the a/t and the m/t torque mounts.
Old 14 Apr 2009, 05:49 pm
PT_Cuda's Avatar
They may have different numbers but they are the same part.. I've changed both auto and 5-speed cars they are the same. The set above in the pic came out of a 5-speed, but the replacements for these came out of an auto. They were filled with window weld and caused too much vibration for the owner of the Auto, so I scored a smoking deal on them. Mounted right up no issues..
They are also the exact same part for the SRT4(neon) 03-05 cars.. Cause we share basically the same front assembly motor and suspension, brakes and whatnot.
Or another thing you can try if your mounts still look decent but are just floppy is motor mount inserts.. You can see in this pic how an insert will beef up a stock mount and give it less flex. Downside is that this can cause too much vibration for some people. And its worse in the Automatic cars than the 5-speed cars. I know we have both at our house and the filled mounts were horrible in the auto but I don't notice a thing in my 5-speed both 03 GT's..
Linky where I got mine for my N/A car, red is the "race" black is the "street" race being a harder compound than the street inserts.
http://www.modernperformance.com/pro...t4-p-1131.html
Old 14 Apr 2009, 10:04 pm
The neon srt-4 mounts are ten times better than the flimsy PT mounts.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 15 Apr 2009, 09:01 am
Thanks for the responses. This works out well, my stealership's out of auto mounts but has the 5 speed ones. I just need a cheap set to get me going, and im going to fill my broken ones
Old 15 Apr 2009, 09:06 am
I'm all for the inserts. I had the rex ones in my Neon back in the day.
I'll check around for a set of prothanes or energy ones.
Stupid motor rocking back and forth broke my header at the collector
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
