Check Engine Light - Help!
Old 16 Apr 2009, 03:32 pm
Default Check Engine Light - Help!
Hi guys,
I have an 04 Pt Cruiser 2.4L Turbo (low output) with 81K miles on it and just got my first check engine light. I had it diagnosed and the code is P0572 BRAKE SWITCH #1 CIRCUIT LOW. Anyone know what this means or how to fix it? I'm hoping it's something minor like a fuse or something. Any input on this would be great. Thanks.
04 PT Cruiser, 2.4L turbo
Black with Chrome Rims
Old 16 Apr 2009, 03:58 pm
PT_Cuda's Avatar
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Default Re: Check Engine Light - Help!
Originally Posted by loki547 View Post
Hi guys,
Lets cover the easy stuff:
Brake fluid - is it full?
Brake pads - are they are in decent shape or worn?
I make people mad.. Its what I'm good at..
Old 16 Apr 2009, 04:31 pm
Brake Fluid is full. Pads I had changed out about 10,000 miles for the front and 15,000 miles for the back. I mostly freeway drive (light traffic) so I'm assuming they're still in pretty good shape.
Old 16 Apr 2009, 05:16 pm
Did a search and found ...
PT Cruiser: P0572 Low Voltage Detected at the Brake Switch
Trouble Code: P0572
Brake Switch Signal No. 1 Circuit Low
Trouble Code Conditions:Ignition is on. When PCM recognizes that brake switch is mechanically stuck in the low/on position, a DTC will set. Three global good trips are necessary to turn off MIL.
Possible Causes:
* Brake switch signal circuit is shorted to ground
* BS No. 2 signal open
* Brake switch is damaged or has failed
* PCM has failed
Old 16 Apr 2009, 05:41 pm
PT_Cuda's Avatar
Cool just doing the "Damn I didn't think of that!" It happens a lot with CEL's or the ABS light..
Crewzin has you covered
Old 16 Apr 2009, 06:18 pm
white's Avatar
And it might just go off anyway. Try undoing the neg battery connection and see if that clears the light. My check eng light was on and off for 20,00 miles and now is off all of the time after I had the timing belt done, which probably has nothing to do with the light. See if it will go off and stay off for a while befor you really worry. It could even be that you need a new gas cap, because a bad cap will turn the light on. But maybe???
E. White
2010 Black over Silver, Couture Edition
Old 16 Apr 2009, 06:23 pm
Trouble Code: P0572
Possible Causes:
* PCM has failed
Thank you everyone for the advice! Crewzin where did you find this info? I did a google search and searched this board and couldn't find anything. It's probably one of the first three since I'd know if my PCM failed.
Anyone know where the brake switch is located? Expensive to replace, etc. And yes White I did have Pep Boys clear the code and the check engine light came back on about two days later with the same code, hopefully it's not too expensive to fix/repair
Old 09 Apr 2011, 07:32 pm
I have 2004 pt cruiser with code P0572 and I know it is the brake switch. How do you check it?
Old 09 Apr 2011, 07:59 pm
Look under the dash by the top of the brake pedal. It's a square white box. Haven't changed it myself but doesn't look too hard to replace.
Old 03 Jan 2012, 11:28 pm
I have the same problem. My oil light comes on and goes off. my check engine light came on a couple weeks ago and will not go off.. every now and then it will blink then beep. then it stays on. I haven't tried disconnecting the battery yet. I just bought it in June, used. its a 2007 model on driven in Los Angeles.
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 17 17 Sep 2015 11:54 am
Check engine light, skipping ab1 Tech & Performance Forum 2 02 Aug 2008 11:13 pm
06 turbo check engine light 06SilverTurbo Tech & Performance Forum 23 21 May 2008 02:20 pm
Faulty Check engine light? Mel K General Turbo Discussions 5 23 Mar 2007 10:06 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
