DRB box, which one is the best
Old 28 Apr 2009, 09:02 am
Default DRB box, which one is the best
I work on mainly Chryslers in my spare time and have an AutoXray 5000 scanner that works pretty well most of the time at least for engine problems. I would like to get a DRB III or better box to be able to program keys an reset the security/immobilizer systems. Which one is the best, what cables do you have to have, and what all else do I need to look for when buying one.
Thanks,
Old 29 Apr 2009, 06:01 am
Default Re: DRB box, which one is the best
The only choices are the DRB-III for non-CANbus systems and the Star-Scan / Star-Mobile for newer systems.
Either way, You will need subscription access to DelaerConnect or TechAuthority to get the PIN nunbers to work with the security systems or any module that needs a VIN programmed. A lone scanner wil not let you get into the modules without the PIN numbers from Chrysler.
